Thread: Aeroforce Interceptor Not Working
Results 1 to 7 of 7
  1. #1 Aeroforce Interceptor Not Working
    GT Level Member TheAce144's Avatar
    Dec 2010
    Montreal, Canada
    Hello, I recently bought an Aeroforce Interceptor scan gauge from zzperformance.com. I have an 04 Grand Prix GTP and therefore ordered the PT version (PT 401 V2.8).
    In scan mode, screen turns black after 2-3 seconds. When I touch the buttons, lights blink red. So basically it's not a power issue.
    I searched on forums but haven't found my answer. It is plugged to the OBDII only and the jumper is still on. I haven't used the optional 3 wire harness. I also selected limited parameters, (RPM and MPG), in case some were not compatible, and still shuts down when putting it in scan mode.
    I would really appreciate some help with this issue.
    Thanks for your time.
    04 GTP CompG: SSAC Headers, 3.6" Modular Pulley System, Autolite 104, NGK Spark Plug Wires, CAI, ZZP 180 T-Stat, Overkill PCM (Custom Street Tuning By Will), Goodyear Eagle F1 Tires, Hawk HPS Brake Pads, Magnaflow Magnapacks 4", SE Front Fascia
    Check Out My Car! ---
  2. #2 Re: Aeroforce Interceptor Not Working
    you need to use that 3 wire harness, the aero needs a constant 12v power source.
  3. #3 Re: Aeroforce Interceptor Not Working
    GT Level Member 04BlackComp_G's Avatar
    Apr 2008
    Rockport, ME
    Since you have an 04 you can use a jumper, meaning a jumper from a computer motherboard. You can get them for free at most computer stores. I got mine from the geek squad at best buy. Draws the power directly from the obd port.
    2009 G8 GT #1311 of 1949:CTS-V front/Camaro rear brakes, Solo Performance axle back exhaust
    2006 GP GXP: ZZP catback, k&n intake, retrofit headlights, cts-v brakes
    2007 Escalade ESV:family hauler
  4. #4 Re: Aeroforce Interceptor Not Working
    Dec 2010
    Montreal, Canada
    Quote Originally Posted by 04BlackComp_G View Post
    There is already the stock red jumper that came with it...I need to change it? I don't get it sorry
  5. #5 Re: Aeroforce Interceptor Not Working
    Dec 2010
    Montreal, Canada
    Not in the 04 Grand Prix, it's supposed to be plug and play...
  6. #6 Re: Aeroforce Interceptor Not Working
    Dec 2010
    Montreal, Canada
    Aeroforce replied to the email I sent them and attached a return form...they won't charge me for repair right? I bought it August 17th...
  7. #7 Re: Aeroforce Interceptor Not Working
    they shouldnt, if you just bought it, they will give you a brand new most likely.
  1. Aeroforce Interceptor-where to purchase?
    By Liquifire in forum General Tech Discussion
    Last Post: 07-16-2009, 12:30 AM
