thanks for the steps for removing the 4 bolts. I will have a helper underneath to hold the ratchet. The hard part will be getting to the bolts.
Its been a while since I assembled, when putting it back together , will it I need to loosen the headers -or- can I just insert the crossover and new gaskets and tighten away?
Steps
1) remove front crossover flange bolts
2) remove rear crossover flange bolts by collector. Having a buddy helps
3) remove crossover
4) replace gaskets. you might have to loosely tighten bolts to keep new gaskets in place
5) put crossover back with gaskets. position for no leaks
6) tighten top, then bottom and repeat sequence until tight
7) check for leaks
