Thread: Best way to replace the TOG gasket
Results 1 to 16 of 16
  1. #1 Best way to replace the TOG gasket
    Jun 2012
    norwell
    Its been 5 years since I installed the TOGs and I get older and forget stuff.
    Looking at the TOG gaskets, I don't think I can simply remove the flange bolts to replace the gasket.
    Any tips to replacing the gasket? Not sure if I have to loosen front&rear headers.
    Thank you
  2. #2 Re: Best way to replace the TOG gasket
    If you pulled the crossover, it would be easier than pulling front/rear
  3. #3 Re: Best way to replace the TOG gasket
    Jun 2012
    norwell
    there are 2 bolts at the top gasket and 2 bolts down by the tranny dipstick. is it as simple as removing those bolts and removing the cross over?
  4. #4 Re: Best way to replace the TOG gasket
    Yes.. however.. I hate TOGS because of that rear crossover connection point. I've found it typically requires two guys ... unless you bind bolts/studs into one side and make it a one man job.
  5. #5 Re: Best way to replace the TOG gasket
    be nice if those flanges were v band clamps.
  6. #6 Re: Best way to replace the TOG gasket
    Buffalo
    You mean the nuts are NOT welded on already for you ?
    That would suck....
  7. #7 Re: Best way to replace the TOG gasket
    Buffalo
    Donut gasket and some right stuff rtv
  8. #8 Re: Best way to replace the TOG gasket
    Nuts were not welded on any of the ones I have installed.
    I found that ICM studs with extra nuts etc worked well to make it one man vs two guys fighting it.
  9. #9 Re: Best way to replace the TOG gasket
    Buffalo
    So it's possible I'm either lucky or you're very unlucky ?
  10. #10 Re: Best way to replace the TOG gasket
    Probably a newer version. All the ones I've ever been given to install.. didn't.
  11. #11 Re: Best way to replace the TOG gasket
    Jun 2012
    norwell
    thanks for the steps for removing the 4 bolts. I will have a helper underneath to hold the ratchet. The hard part will be getting to the bolts.
    Its been a while since I assembled, when putting it back together , will it I need to loosen the headers -or- can I just insert the crossover and new gaskets and tighten away?
    Steps
    1) remove front crossover flange bolts
    2) remove rear crossover flange bolts by collector. Having a buddy helps
    3) remove crossover
    4) replace gaskets. you might have to loosely tighten bolts to keep new gaskets in place
    5) put crossover back with gaskets. position for no leaks
    6) tighten top, then bottom and repeat sequence until tight
    7) check for leaks
  12. #12 Re: Best way to replace the TOG gasket
    you got old school donuts in the flanges, not a gasket. looks like you'll have to at least loosen up the front header too.
  13. #13 Re: Best way to replace the TOG gasket
    Buffalo
    Damn Bill, what blower was that ?
  14. #14 Re: Best way to replace the TOG gasket
    Honestly..I have never done it on a car at that point, I'd say. wing it a touch.. I bet you can remove just the 4 bolts, replace the donuts and be done.
    Took you long enough to notice that Bob That's a 112 with adapter plate IC.
  15. #15 Re: Best way to replace the TOG gasket
    Buffalo
    It's. It's beautiful ... I guess you ARE lucky
  16. #16 Re: Best way to replace the TOG gasket
    Was a customers, not mine.
  1. Change LIM gasket what else should I replace at the same time?
    By 71gs3504sp in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-21-2014, 04:51 PM
  2. Shop Wants $600 To Replace Oil Pan And Gasket???
    By 97GTzbban1 in forum General Tech Discussion
    Last Post: 07-24-2010, 04:26 AM
  3. stripped threads!! Replace gasket??
    By dgiles79 in forum General Tech Discussion
    Last Post: 07-13-2010, 06:25 AM
  4. What tools and parts are needed to replace the LIM gasket on the S/C 3800 motor?
    By Spazztic2003 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-28-2009, 09:46 AM
  5. Vaccuum Squeal after Head gasket replace
    By hesersypb in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-14-2009, 11:46 AM
