Thread: Intermittent Starting Issue
Results 1 to 20 of 25
  1. #1 Intermittent Starting Issue
    GTP Level Member bonerjamz03's Avatar
    Apr 2009
    Upper Darby, PA
    97 GTP. I've been having an issue with my car starting over the past week. Sometimes it will start, other times nothing happens (no lights no sounds), other times I get lights with a no start no crank. I've also had issues with the shift lock release, but I don't think that would be the cause.
    I checked the battery (which is a couple years old) cable connections and voltage, the alternator was replaced earlier this year, and I did the ignition switch a couple of years ago. I haven't been driving it since I don't want to get stranded and have to get it towed. Any ideas?
  2. #2 Re: Intermittent Starting Issue
    St. Louis
    Ignition switch maybe?
  3. #3 Re: Intermittent Starting Issue
    Apr 2009
    Upper Darby, PA
    Possibly, but it was already replaced not too long ago.
  4. #4 Re: Intermittent Starting Issue
    Feb 2013
    37.295091, -121.930053
    wire loose? or bad ground
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  5. #5 Re: Intermittent Starting Issue
    GT Level Member sugaryuk's Avatar
    vancouver,bc
    Check the wiring harness under the battery tray. Mine dripped some battery acid onto my harness and actually ate through some wires causing all sorts of weird electrical issues.
    02 GT- L32/Gen V, 3.3 mps, zz 1.9's, N*, slp front to back, OverKilled, 180 tstat, 104's, K&N cai, lowered with GMMP susp, 12" PBR brakes
    75 Pro-Street Vega-- Blown 383 stroker with Nos fogger system
  6. #6 Re: Intermittent Starting Issue
    Apr 2009
    Upper Darby, PA
    Anyone have a diagram with the ground locations on it?
  7. #7 Re: Intermittent Starting Issue
    follow the neg bat cable, it leads to the tranny bell housing bolt where its grounded, with 2 other wires on most cars.
  8. #8 Re: Intermittent Starting Issue
    Apr 2009
    Upper Darby, PA
    Thanks Scotty. I cleaned up the battery terminals today even though they weren't too bad and I noticed the ring connector at the top of the fuse block in the engine bay is pretty f'd up. Would that cause a starting issue? I'm gonna replace it regardless.
  9. #9 Re: Intermittent Starting Issue
    it can. if you take it off the car has no power.
  10. #10 Re: Intermittent Starting Issue
    Apr 2009
    Upper Darby, PA
    It would be nice if that's the only problem but it's probably not lol. Now if only this ****ty hurricane weather would go away I can work on it.
  11. #11 Re: Intermittent Starting Issue
    Apr 2009
    Upper Darby, PA
    Figured I'd start checking wires today so I pulled the console apart and found some broken ones to the shift release. It looks like a pink and an orange/black wire which broke. Is there a way of getting the pin out of the connector plug so I can resolder them or am I looking at a trip to the junkyard?
  12. #12 Re: Intermittent Starting Issue
    you'll need a light and a pick to get the wires out, ( most have a little lever to move inside) or just junk yard a whole pig tail, and solder it on.
    theres a youtube vid where a guy bought a roll of a 1,000 pins and hes selling them for very cheap. same issue shift lock wires broke off.
  13. #13 Re: Intermittent Starting Issue
    Apr 2009
    Upper Darby, PA
    Junkyard it is. This shouldn't have anything to do with the starting issue would it?
  14. #14 Re: Intermittent Starting Issue
    not really. most of the time its a key wont turn back or it wont shift out of park type deals.
  15. #15 Re: Intermittent Starting Issue
    Apr 2009
    Upper Darby, PA
    Yeah, kinda what I figured. Oh well at least I won't have to use a screwdriver to drive the car anymore lol.
  16. #16 Re: Intermittent Starting Issue
    Apr 2009
    Upper Darby, PA
    I got the wires soldered into the connector today. It shifts without a screwdriver and it starts up and runs good. i still need to clean the grounds but maybe I got lucky this time with an easy fix.
  17. #17 Re: Intermittent Starting Issue
    Apr 2009
    Upper Darby, PA
    Well it's back. No lights, no clicks, nothing. I took it over to Advance last week when it was running and had them do an electrical system check and that all came back fine. I checked grounds, fuses, looked for loose connections. I'm tempted to take it to the mechanic but would rather not since money is tight at the moment.
  18. #18 Re: Intermittent Starting Issue
    play with the plug and the new soldered wires, never know. that whole pig tail must move when shifted, why else would the wires just break off for no reason?
  19. #19 Re: Intermittent Starting Issue
    Apr 2009
    Upper Darby, PA
    Already tried. I jiggled, tapped, played with every wire and connector I could see. Is there a solenoid or relay in the starting circuit that you know of that could cause this?
  20. #20 Re: Intermittent Starting Issue
    ive heard of the whole shiftier going bad. causes the same issue. junk yard swap is the cheap way, iirc the dealer wanted 300 for one in a thread i saw a long while back.
  1. 1997 GTP intermittent starting issues
    By GTP1997 in forum General Tech Discussion
    Last Post: 03-16-2012, 08:04 PM
  2. Intermittent stalling issue *NOT CPS EITHER*
    By PokerBlakeB in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-23-2011, 02:19 AM
  3. Intermittent Starting Problem...
    By Claude in forum General Tech Discussion
    Last Post: 03-17-2011, 08:33 PM
  4. 94 GP 3.1 Auto - intermittent starting problem
    By Dergibog in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-04-2011, 07:41 PM
  5. Intermittent Starting Stalling Issue
    By daniel981 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-04-2009, 07:20 AM
