Thread: Intermittent Starting Problem...
Results 1 to 9 of 9
Claude Intermittent Starting... 06-11-2010, 11:31 PM
gpbastard Re: Intermittent Starting... 06-15-2010, 07:51 PM
gpbastard Re: Intermittent Starting... 06-15-2010, 07:56 PM
TheOtherNick Re: Intermittent Starting... 06-15-2010, 08:00 PM
gpbastard Re: Intermittent Starting... 06-15-2010, 09:34 PM
CTKGP09 Re: Intermittent Starting... 06-15-2010, 10:47 PM
Claude Re: Intermittent Starting... 06-19-2010, 04:14 PM
Jhowie Re: Intermittent Starting... 03-17-2011, 08:33 PM
TheOtherNick Re: Intermittent Starting... 06-15-2010, 10:13 PM
  1. #1 Intermittent Starting Problem...
    SE Level Member Claude's Avatar
    Elkhart IN
    Hey guys, I am hoping to pick your brains on a issue I've been having...
    On my parents 96 Buick Regal, it has a starting problem of sorts. Where 60% of the time it starts fine, but that other 40%, you turn the key, and nothing happens, lights dim a very small amount.
    Yes, you say that could be a host of issues. The starter is good (IE replaced a couple of times, trying to fix this problem), the ignition lock cylinder should be good (replaced trying to fix this problem).
    The main battery cable, has juice going to it. It is the other wire, that seems to not get juice when it is suppose to (you can jumper it, and it will engage). The relay has been replaced, and the fuses look to be good.
    Do you guys think there might be a short in the system? Where is the neutral safety switch, and could that be the problem?
    Thanks for the help guys,
    Claude
  2. #2 Re: Intermittent Starting Problem...
    GT Level Member gpbastard's Avatar
    Florida
    Quote Originally Posted by Claude View Post
    Claude
    i would check for a bad connection in the starting system. check the connections going to the starter and take them off and clean them. also, check the ground wire going from the battery negative to the chassis....
  3. #3 Re: Intermittent Starting Problem...
    Florida
    Quote Originally Posted by gpbastard View Post
    you can try wiggling the shifter when you start it that may help to see if the neutral start switch is bad. also, when you troubleshoot always start with the easy stuff first then move up, not the other way around...
  4. #4 Re: Intermittent Starting Problem...
    Charles City, IA
    had the same problem with a 96 boneville, just installed a push button starter on the dash for when the key does not work.
    SMGPFC Two Nipple General
  5. #5 Re: Intermittent Starting Problem...
    Florida
    did you ever find out why it wouldn't start?
  6. #6 Re: Intermittent Starting Problem...
    Willoughby, Ohio
    probably the best fix ive ever heard, hmm this dont work...eh f*** it put in a button instead... haha love it
  7. #7 Re: Intermittent Starting Problem...
    Elkhart IN
    So how do you install the push button? hahahaha
    The starter solenoid wire is good, I replaced that connection just for good measure.
    Neutral safety switch, replaced. Ignition switch (the fat thing that sits on top of the steering column, with a ton of wires going to it) replaced. Ignition relay, replaced.
    Sooooo, I am at that point I think, where I am in need of some wiring diagrams, to trace where something is loose. Any ideas where I could get them guys? I need to know where all these wires run, short of unwrapping the entire wiring harness
  8. #8 Re: Intermittent Starting Problem...
    Virginia
    Did you ever get your car starting problem fixed? I have a 92 GP SE and I am having the same problem and have replaced the same parts. Any suggestions? Thanks
  9. #9 Re: Intermittent Starting Problem...
    Charles City, IA
    It was in the gear selector switch on the tranny.
  1. Fixing your intermittent stalling problem!
    By Pittman06 in forum How To Write-Ups/Tech Tips
    Last Post: 05-14-2013, 09:35 PM
  2. Intermittent dying problem with 00 GTP
    By ls6velless454 in forum General Tech Discussion
    Last Post: 04-08-2010, 12:11 PM
  3. Intermittent Starting Stalling Issue
    By daniel981 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-04-2009, 07:20 AM
  4. Starting Problem
    By SHayes in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-05-2009, 02:49 PM
  5. 06 GT SC starting problem
    By BHMJohn in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-30-2009, 11:38 PM
