Thread: HELP Under dash wiring FIRE need help with wiirng please
Results 1 to 20 of 27
  1. #1 HELP Under dash wiring FIRE need help with wiirng please
    May 2011
    New Hudson, MI
    Recently my wife went to start my car (2001 GTP) and smoke starting rolling out from the dashboard. Called the insurance company, they came and took pics and said no fire no claim. They called it a "wire malfunction" what the **** is that? Basically in one area all the wires melted together under the dash and melted some plastic around it. I'm trying to just replace one wire at a time but I ran into about 8 solid orange wires 8 or so solid pink wires and a hand full of solid yellow wires. Now what do I do? I have no idea which orange, pink or yellow wire they go to. Any help would be greatly appreciated. I will post pics shortly.
    Ive searched junk yards with no luck plus im not sure if 97-03 had the same harness or do I need to find a specific model or year. I did find the part number on the harness 10305785.
  2. #2 Re: HELP Under dash wiring FIRE need help with wiirng please
    Feb 2013
    37.295091, -121.930053
    i would personally go get a new harness from the junk yard and just replace the whole thing
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: HELP Under dash wiring FIRE need help with wiirng please
    May 2011
    New Hudson, MI
    Are all the dash harnesses the same or do I specifically need an 01 gtp harness?
  4. #4 Re: HELP Under dash wiring FIRE need help with wiirng please
    wheres the wires burnt?
    in the column your looking at the clock spring, the multi switch and ignition harness's all tie together so all could be f ed up.
  5. #5 Re: HELP Under dash wiring FIRE need help with wiirng please
    May 2011
    New Hudson, MI
    Quote Originally Posted by ScottyDoggs View Post
    Directly behind the glove box about a 6 inch length of wire maybe 30 wires. I'll get pics up soon. Ive searched junk yards in my area and outside but have had no luck in over a month of searching. Nothing on ebay either.
  6. #6 Re: HELP Under dash wiring FIRE need help with wiirng please
    Quote Originally Posted by LugNutLX View Post
    this the fat harness thats entering the cars cab from the firewall? thats like the main harness if so.
  7. #7 Re: HELP Under dash wiring FIRE need help with wiirng please
    May 2011
    New Hudson, MI
    Yes thats the part. It has all the thick wires going to the fuse block. Anyone have a good harness they want to sell?
  8. #8 Re: HELP Under dash wiring FIRE need help with wiirng please
    Feb 2013
    to replace the whole thing is the best way other wise you will have more problems than you know. ecm going out, random check engine light, random abs light etc.
  9. #9 Re: HELP Under dash wiring FIRE need help with wiirng please
    Jul 2010
    Coquitlam,BC,Canada
    So no different from a good harness. LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  10. #10 Re: HELP Under dash wiring FIRE need help with wiirng please
    thats not gonna be fun at all.
    that guy idrivejunk, iirc hes got a 01 or 02 that he tore the dash out for his other car. maybe shoot him a pm asking if hes still got the car. no idea if he scrapped it or not. it was in a roll over iirc.
  11. #11 Re: HELP Under dash wiring FIRE need help with wiirng please
    May 2011
    New Hudson, MI
    Thanks Scotty, I appreciate your guys help!
  12. #12 Re: HELP Under dash wiring FIRE need help with wiirng please
    Jan 2014
    AR
    Yep Scotty I scrapped it long ago. That harness was too much work to keep intact so I chopped off and kept the pigtails only.
  13. #13 Re: HELP Under dash wiring FIRE need help with wiirng please
    i tried.... iirc the last pic i saw it was on a trailer too.
  14. #14 Re: HELP Under dash wiring FIRE need help with wiirng please
    hangover park IL
    I have a forward half wiring harness assembly for a 2001 Grand Prix, non GTP (engine harness is primary difference.
    it's basically everything forward of the bottom of the B pillars.
    removing this harness took an entire day at the junkyard. and that was not with careful removal.... this was using sawzalls and hammers to disassemble the dashboard.... installing this is going to be fun....
    It's in a large Rubbermaid bin with all brainboxes still connected...about 75-100lbs ish....
    I probably shouldn't even offer this since I only have one other complete harness to use with the 442.
    you can get the factory wiring diagrams and just do point to point circuit identification and then repair the current wiring
    ~James~ Psychotic Gearhead
  15. #15 Re: HELP Under dash wiring FIRE need help with wiirng please
    Jan 2014
    AR
    Quote Originally Posted by Turbocharged400sbc View Post
    This is what I'd do, fix whats there.
  16. #16 Re: HELP Under dash wiring FIRE need help with wiirng please
    May 2011
    New Hudson, MI
    Quote Originally Posted by idrivejunk View Post
    This is what i've started to do but after I repaired all the striped colored wires now im left with orange yellow pink and black solid wires and 3 different ways they could possibly go. I guess I could undo the whole harness and follow them to where they go but what a pain in the ass that will be.
  17. #17 Re: HELP Under dash wiring FIRE need help with wiirng please
    hangover park IL
    go to the wiring diagrams
    a lot of fuses will have multiple wires of the same color leaving them, sometimes with different thickness' as each fuse will feed several systems/components
    the wire colors your listing GM uses on mostly the primary electrical power feeds. devices and between devices wires tend to be smaller and have tracers if the primary color is one of the ones listed.
    therefore its likely all primary power feeds tpo various modules/computers/lights etc
  18. #18 Re: HELP Under dash wiring FIRE need help with wiirng please
    Jan 2014
    AR
  19. #19 Re: HELP Under dash wiring FIRE need help with wiirng please
    wow. thats a lot orange and yellow and pink wires..... thanks again GM lol
  20. #20 Re: HELP Under dash wiring FIRE need help with wiirng please
    hangover park IL
    its cheaper by the 1 ton spool
  1. #1 Cyl Mis Fire
    By 88ironduke in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-30-2010, 07:58 PM
  2. my a$$ is on fire...lol
    By cojo in forum General Tech Discussion
    Last Post: 05-10-2009, 09:32 PM
  3. Mis-Fire #5
    By gtbeach in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-06-2009, 11:39 PM
