Thread: Switched 12V source?
Results 1 to 14 of 14
  1. #1 Switched 12V source?
    Slower, Lower Delaware
    I'm putting gauges in the a-pillar. Where's the closet or easiest 12V switched connection?
  2. #2 Re: Switched 12V source?
    the fuse box is what i used, just ran a wire to a ing off fuse, like the wipers.
  3. #3 Re: Switched 12V source?
    I think I read somewhere there's an opening on the passengers side that's good to run cables through. It seems that would make close access to the fuse box.
  4. #4 Re: Switched 12V source?
    i just snaked the wires up in the dash, theres lots of room when you take the bottom covers off.
    there is a power drop on the driver side, mine was up near the dash looking up from the right side of the steering wheel.
  5. #5 Re: Switched 12V source?
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Just to clarify, he was talking about the fuse box behind the glove box and not the main fuse box in the engine bay.
    Theres a grommet below brake booster that already has hvac line runing through it that can be used for running lines/wires from engine bay through firewall up under dash and to a pillar pod.
  6. #6 Re: Switched 12V source?
    i ran some ground wires out the shiftier cable grommet to the battery. and the wide band wires through it too.
  7. #7 Re: Switched 12V source?
    Thanks for clearing up my confusion and for the extra information.
  8. #8 Re: Switched 12V source?
    use a add a fuse. like this.
  9. #9 Re: Switched 12V source?
    What size does a 2005 take atm, atm-lp?
  10. #10 Re: Switched 12V source?
    you mean a mini add a fuse, or the large one? if so you want the mini. all new cars use the small fuses these days it seems.
  11. #11 Re: Switched 12V source?
    I picked up an add a fuse in ATC but its too big to plug in. I guess I'll take a fuse out and take it with me.
  12. #12 Re: Switched 12V source?
    theres only two sizes, large, and its huge two times the width of the mini, and small.
  13. #13 Re: Switched 12V source?
    Kemmerer, Wyoming
    you need the mini add a fuse to use on the fuse block in the glove box compartment
  14. #14 Re: Switched 12V source?
    Thanks to you all.
  1. Just switched to E85... Here's what I learned!
    By 97AutoXVette in forum General Tech Discussion
    Last Post: 07-11-2014, 09:07 PM
  2. Need a 12v switched source for seat heaters.
    By TheMadcat in forum Audio, Security & Visual Electronics
    Last Post: 01-03-2014, 06:48 PM
  3. switched accessory tap
    By ham4864 in forum Audio, Security & Visual Electronics
    Last Post: 12-10-2010, 11:21 PM
  4. Switched Ignition Source
    By Blackhawk in forum Audio, Security & Visual Electronics
    Last Post: 11-15-2009, 05:51 PM
  5. 12volt switched source?
    By nyydmb12 in forum Audio, Security & Visual Electronics
    Last Post: 10-19-2009, 06:45 AM
