Thread: RWD L67 swap
Results 1 to 13 of 13
  1. #1 Re: RWD L67 swap
    You'll need to get the computer tuned for the mods and the lack of transmission.
    You should be able to shut off all trans related codes and disable and torque management and all the abuse tables that likely limit the rpm to the 4,000 park redline. Factory shift points in any other gear was 5300-5500 rpm.
  2. #2 Re: RWD L67 swap
    Punxsutawney, Pa
    Thanks, that's basically what I figured. I have a DHP Tuner, but I am quite the novice with it haha. I was able to pull the bin and see where I can change the park and neutral rpm limits. I've been reading up on how to disable the torque management as well and should be able to do that when I get a chance
  1. Tuning Issues, 04 GT (L32 Swap / Gear Swap)
    By RivMan in forum PCM Tuning
    Last Post: 09-12-2013, 08:37 PM
  2. Engine swap or top swap
    By 06PONTGP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2013, 12:01 AM
  3. l67 swap, trans swap
    By MrPhotographer06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2012, 07:11 AM
  4. Replies: 1
    Last Post: 12-31-2011, 04:55 PM
  5. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
