Thread: Name that sound
Results 1 to 10 of 10
  1. #1 Name that sound
    Apr 2015
    Lincoln NE
    Today my 97 gtp started making a strange noise when it was in gear and throttle was applied.(it is normal in neutral) It is a whirring noise that happens whether i am moving or not and changes pitch with rpm speed. Here is a video of it. I don't know if it is tranny related or what.
    https://drive.google.com/file/d/0Byw...ew?usp=sharing
  2. #2 Re: Name that sound
    sounds like the trannys slipping, but your also in a parking garage, so who knows.
  3. #3 Re: Name that sound
    Apr 2015
    Lincoln NE
    ya the parking garage made it show up better on camera. It is pretty loud. Between that noise and the open cone it really turns some heads.
  4. #4 Re: Name that sound
    hows the steering feel? the fluid could be low.
    or the trans pump is starving for fuild from a clogged up filter or something.
  5. #5 Re: Name that sound
    Apr 2015
    Lincoln NE
    It definitely is not the power steering. I have heard that before. I just had the filter and oil changed a couple thousand miles ago but how would I check that?
    It seems like it could be the torque converter. Would that be possible?
  6. #6 Re: Name that sound
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    sounds like trans front pump whine
  7. #7 Re: Name that sound
    Apr 2015
    Lincoln NE
    is that a bad thing? or let it go?
  8. #8 Re: Name that sound
    May 2011
    Illinois
    check fluid of course, and if it were me, id drop the pan and have a looksie
  9. #9 Re: Name that sound
    Apr 2015
    Lincoln NE
    Well definitely something wrong. I now have no gears and an aweful grinding in gear.... Off to the tranny shop
  10. #10 Re: Name that sound
    Can't hear it.. because of where i am. Sounds like you've "narrrowed" it down to trans...lol
  1. Grinding sound when making sharp left and awful creak sound when going over bumps
    By rescuetoaster in forum Brakes/Suspension/Chassis
    Last Post: 03-04-2012, 10:06 PM
  2. What's this sound like to you?
    By kissmyss in forum Brakes/Suspension/Chassis
    Last Post: 07-02-2011, 04:02 AM
  3. new sound:)
    By beckys2000gt in forum General Tech Discussion
    Last Post: 07-03-2010, 06:19 PM
  4. how to get more sound out of s/c?
    By gtphayes in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-05-2010, 01:31 PM
  5. new to this sound...?
    By X97prixX in forum Brakes/Suspension/Chassis
    Last Post: 11-03-2009, 01:52 PM
