Whatever. Now you are saying I'm being disingenuous to prove some false ascertain you think I'm making? My ac was off in all scans. I keep it off when I'm tuning. I wasn't cherry picking parts of my scans to prove a point. I have dozens of logs that will prove the only point I was making, which I'll say one last time...running the fans at highway speeds will reduce ect's. I know this for a fact because I've logged it and seen it with my own eyes. Before I lowered my fan on temp, my car would NOT go lower than 200°. Cruising, idling, with AC off it would not go lower.he first graph is like halfway through a run I have no idea other than you are running no AC I would venture to guess, and it is a short snippet of your trip
the second one is comparable but your running your fans all the time.
the third graph is a hand picked end of a high speed run where it looks like you are tailing someone going slower than you and holding 3rd gear I would say based on your RPM's
Which adds to the confusion coming through in your posts. Because you just said this:I know they will come on while going freeway speeds or my temp would have kept climbing over 217 as it shows in one of the graphs I posted.
To me because I said:I have to wholeheartedly disagree with just about everything in that statement.
"Because there is no "at speed". You will always benefit by fans unless you are going 145, which is the only speed at which the fans shut off. "
Now I'm so confused I can't even make sense of what you disagreed with lol. You "wholeheartedly disagreeing" with my post is the only reason I went through all the trouble proving my claims with data.
Bottom line and I'm out...your car runs hot because you live in a desert and drive a heaton. Tune your fans or go through all the trouble of installing a larger radiator... Like I did...and see no improvement.
