Thread: ABS and Trac off light Problems
Results 1 to 5 of 5
  1. #1 Re: ABS and Trac off light Problems
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    does your scanner even read ABS codes ? many of them don't or will only read certain makes. if there's a ABS Light then there is a code. take it to a garage with a better scanner. if they can't get a code it's most likely the ebcm is having issues. or you can try this....
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  1. ABS light and Trac Off light come on at same time
    By kking89 in forum Brakes/Suspension/Chassis
    Last Post: 10-26-2013, 04:16 PM
  2. abs light on, trac ctrl light off, what does this mean?
    By tcman49 in forum Brakes/Suspension/Chassis
    Last Post: 10-22-2013, 03:04 PM
  3. ABS light on, Trac Off light on, New hubs all around
    By tdm571 in forum Brakes/Suspension/Chassis
    Last Post: 06-12-2011, 07:44 PM
  4. Trac off light, Brake light on?
    By 1badregal in forum Brakes/Suspension/Chassis
    Last Post: 10-17-2010, 10:24 AM
  5. Airbag cluster light? ABS/Trac light too?
    By oddwraith in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-15-2009, 09:57 AM
