Thread: ABS and Trac off light Problems
Results 1 to 5 of 5
  1. #1 ABS and Trac off light Problems
    TN
    02 GP GT
    My ABS and Trac off lights go on and go off.
    For the most part, they are off when I start the car and they usual come on after driving for 5 or 10 miles and stay on until the car is turned off again.
    Here's the strange thing - my wife pointed this out and I though she was crazy, but she's right. When the ABS light is on the car is harder to steer.
    Its not like the power steering is completely gone, but you can definitely tell a difference in steering when the light is on... I don't know how those two are related.
    I disconnected the sensor wires and cleaned them good - no change. Also it does no show a code - at least not one that I can read with my OBDII scanner. No CEL.
    Anyone with a similar problem in the past? Where should I go from here?
  2. #2 Re: ABS and Trac off light Problems
    get the abs scanned or your just chasing your tail.
    your wife is right, ( not crazy) lol the steering gets real firm when the abs light is on. you have magnasteer, its affected by the abs light.
  3. #3 Re: ABS and Trac off light Problems
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    does your scanner even read ABS codes ? many of them don't or will only read certain makes. if there's a ABS Light then there is a code. take it to a garage with a better scanner. if they can't get a code it's most likely the ebcm is having issues. or you can try this....
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  4. #4 Re: ABS and Trac off light Problems
    St. Louis
    GM Tech II will read it for sure. Maybe also a good Snap-On reader. Could be a wire issue with the harness, or a bad hub. On my 00 GPGT it did this for a while and eventually the lights stayed on 24/7. Turned out to be a wire issue inside the harness. Replaced the harness and all is well. Not sure if the 02's have the separate harness from the hub to the main loom or not like the 00.
  5. #5 Re: ABS and Trac off light Problems
    SE Level Member lizahart's Avatar
    Jul 2015
    Canada
    02 GP's harness is just like the 2000s.
  1. ABS light and Trac Off light come on at same time
    By kking89 in forum Brakes/Suspension/Chassis
    Last Post: 10-26-2013, 04:16 PM
  2. abs light on, trac ctrl light off, what does this mean?
    By tcman49 in forum Brakes/Suspension/Chassis
    Last Post: 10-22-2013, 03:04 PM
  3. ABS light on, Trac Off light on, New hubs all around
    By tdm571 in forum Brakes/Suspension/Chassis
    Last Post: 06-12-2011, 07:44 PM
  4. Trac off light, Brake light on?
    By 1badregal in forum Brakes/Suspension/Chassis
    Last Post: 10-17-2010, 10:24 AM
  5. Airbag cluster light? ABS/Trac light too?
    By oddwraith in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-15-2009, 09:57 AM
