Thread: Northstar throttle body - install to cable question
Results 1 to 8 of 8
  1. #1 Northstar throttle body - install to cable question
    Apr 2014
    Not here.
    Im having an issue hooking up my throttle cable to my Northstar TB, it seems the cable is a bit short. Are there any modifications that need to be done to the lever that im missing, or should I get a Northstar throttle cable as well? This seems to be a popular mod but I seem to be missing something obvious here and im not sure what.
    Northstar throttle body - install to cable question Attached Images
  2. #2 Re: Northstar throttle body - install to cable question
    Kemmerer, Wyoming
    its not too short, you just have to use your muscles to put it in. the barrel at the end of the cable is kind of a pain to get in the slot on the throttle body
  3. #3 Re: Northstar throttle body - install to cable question
    Cable: N* had a ball at the end of the TB cable. I take that area where the ball would sit and use a 1/4" drill bit to open it up in order to sneak our cylinder piece into the N* area. Visible on the lower left side of this picture
    For the bracket, I use the N* bracket and make some modifications to it. Also in the above picture, you can see that I slotted the bracket where it bolts to the side of the TB and cut a second bolt hole area off. You end up bending the top of the bracket down on the front of it in order to bring both cables closer, then cut the bracket between the two cables in order to move the cruise closer (IIRC) to the TB.
    Hope that helps out.
  4. #4 Re: Northstar throttle body - install to cable question
    Buffalo
    When did we stop calling that piece at the end of the cable a "hot dog"?
  5. #5 Re: Northstar throttle body - install to cable question
    Quote Originally Posted by RickyBobby03 View Post
    To my knowledge the only guys calling it a hot dog was Dave the Diddler and you.
  6. #6 Re: Northstar throttle body - install to cable question
    Nov 2013
    United States
    Instead of drilling mine I just tweaked the throttle cable bracket. Quicker, easier, more precise.
  7. #7 Re: Northstar throttle body - install to cable question
    Apr 2011
    Elk Rapids, Michigan
    ZZP has a bracket made for GPs for 2000+ Northstar throttle bodies.
    http://shop.zzperformance.com/store/...e-Bracket.aspx
    2001 black GTP coupe, Gen V, ZZP S2IC & billet fuel rails, XP cam, LS7 lifters, 105# springs, ZZP MPS w/3.4 pulley, Northstar tb, LQ4 maf, ZZP headers, K & N CAI, Meziere electric wp, Caspers fp retire, F body front brakes, GMPP strut braces​, Don Rome strut brace mounts.
  8. #8 Re: Northstar throttle body - install to cable question
    15 Minutes and some black paint.. and his car is running.
  1. Northstar throttle cable bracket
    By Impala131 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-14-2014, 07:30 AM
  2. SOLD sold
    By kawasaki22106 in forum For Sale - Parts
    Last Post: 11-26-2013, 02:59 PM
  3. WTB Northstar Throttle Body/LQ4 MAF
    By jayroca in forum Wanted To Buy - Parts
    Last Post: 02-08-2013, 12:21 PM
  4. Northstar throttle body question?
    By XtrmGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-23-2012, 09:57 PM
