All my gauges go dead except my speedo you'll be driving along and they'll all go off like I said including my tcs n my odometer will say error miles... would that have something to do with my Data Link module going out??
check the grounds on the trans bell housing. its where the neg cable from the battery bolts to the engine.
theres two other wires there, the wire can come loose at the end of the eye let and cause off on type stuff.
Got am aftermarket stereo or remote start?
Sent from my VS986 using Tapatalk
So I got an areoforce now n when my gauges go dead my areoforce shuts off the shift lights just blink any ideas on wat it could be?
Sent from my SCH-S968C using Tapatalk
Do you have an AUX module to your factory stereo?
Every single aftermarket stereo harness I tried (PAC and Metra) caused BCM issues, I ended up buying a cheap $5 harness, running a switched 12v wire and just dealing with no chimes.
Last time I had this issue, it was my PAC Aux adapter on the stock Monsoon stereo that had gone bad, made all sort of funky issues. Got rid of it, worked fine, later installed a new radio with a GMOS-04, never had issues in over a year.
