Thread: help.. all gauges go dead except speedo
Results 1 to 15 of 15
  1. #1 help.. all gauges go dead except speedo
    GT Level Member 04GTP4dr's Avatar
    Jun 2015
    hastings, Nebraska
    All my gauges go dead except my speedo you'll be driving along and they'll all go off like I said including my tcs n my odometer will say error miles... would that have something to do with my Data Link module going out??
  2. #2 Re: help.. all gauges go dead except speedo
    check the grounds on the trans bell housing. its where the neg cable from the battery bolts to the engine.
    theres two other wires there, the wire can come loose at the end of the eye let and cause off on type stuff.
  3. #3 Re: help.. all gauges go dead except speedo
    May 2012
    Where winter never ends
    Got am aftermarket stereo or remote start?
    Sent from my VS986 using Tapatalk
    2000 Regal - Winter Beater
  4. #4 Re: help.. all gauges go dead except speedo
    Enfield, CT
    Happened to my once this year. Cleaned up the battery terminals and all was good.
    Sent from my LG G3
  5. #5 Re: help.. all gauges go dead except speedo
    Jun 2015
    hastings, Nebraska
    Yup both but had the remote start disabled at still did it and it did it once befor when I just got my remote start put in
  6. #6 Re: help.. all gauges go dead except speedo
    Jun 2015
    hastings, Nebraska
    So I got an areoforce now n when my gauges go dead my areoforce shuts off the shift lights just blink any ideas on wat it could be?
    Sent from my SCH-S968C using Tapatalk
  7. #7 Re: help.. all gauges go dead except speedo
    GT Level Member hockeybawler's Avatar
    Oct 2011
    huntley
    It is from your aeroforce, happens to mine sometimes. I have not found a fix to it and I know other people have ran into the same issues with it.
  8. #8 Re: help.. all gauges go dead except speedo
    Oct 2011
    Toledo, OH
    Quote Originally Posted by hockeybawler View Post
    It's NOT the Aeroforce. It CAN be caused by any device being connected to the OBDII port, but he's having the issue before if ever bought an Aeroforce.
    7"
  9. #9 Re: help.. all gauges go dead except speedo
    Jun 2015
    hastings, Nebraska
    Any ideas?
  10. #10 Re: help.. all gauges go dead except speedo
    GT Level Member WolvesSoulZ's Avatar
    Québec
    Do you have an AUX module to your factory stereo?
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  11. #11 Re: help.. all gauges go dead except speedo
    Apr 2015
    Idaho
    Every single aftermarket stereo harness I tried (PAC and Metra) caused BCM issues, I ended up buying a cheap $5 harness, running a switched 12v wire and just dealing with no chimes.
  12. #12 Re: help.. all gauges go dead except speedo
    Jun 2015
    hastings, Nebraska
    Bcm issues? Wat you mean?
  13. #13 Re: help.. all gauges go dead except speedo
    BCM = body control module. it maybe fried up.
    have you had the car scanned yet at a shop with a real scanner. i bet you got a load of U and C codes.
  14. #14 Re: help.. all gauges go dead except speedo
    Québec
    Last time I had this issue, it was my PAC Aux adapter on the stock Monsoon stereo that had gone bad, made all sort of funky issues. Got rid of it, worked fine, later installed a new radio with a GMOS-04, never had issues in over a year.
  15. #15 Re: help.. all gauges go dead except speedo
    Jun 2015
    hastings, Nebraska
    I'll have to check that out...but I'm not throwing a check engine light
  1. Speedo
    By crock in forum General Tech Discussion
    Last Post: 10-04-2011, 09:55 PM
  2. No speedo
    By mikebrowncustoms in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-16-2009, 11:17 PM
  3. speedo
    By BankRupt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2009, 12:21 PM
  4. I want this speedo
    Last Post: 04-15-2008, 01:32 AM
