Thread: Door actuator replacement
Results 1 to 5 of 5
  1. #1 Door actuator replacement
    GTP Level Member Grandprix202's Avatar
    Apr 2013
    Fowlerville
    Right before my last day of work I had a mechanic look at why my driver side rear door never locked unlocked. He tore it apart and found out it was actuator. He thought it was going to be about 50 bucks to replace. Our parts guy ordered the wrong part. So that 50$ turned into 200$ from the dealership... So I said f that. I watched how he put it all back together and I'm on my way to the junk yard today. Anyone ever replace one before?
    Sent from my SM-N900P using Tapatalk
    Representing all the N/A out there. Fastest stock N/A you will ever come across.
  2. #2 Re: Door actuator replacement
    GXP Level Member
    Mar 2015
    Tomball
    I took apart my Dr door panel this weekend to see what the deal was with my lock and it looks like a PITA to get to wear gloves for sure I couldn't really see much but it almost looked like it was attached to the latch assembly as well. I didn't even see any other hardware so I am hoping that there are studs on the inside. I am not sure about the rear door but I have 3 that seem to be worn out. I am making a trip this weekend too for the same thing, hopefully some one will chime in with a better answer.
    Jeff
  3. #3 Re: Door actuator replacement
    Apr 2013
    Fowlerville
    Alright I just got back from the junk yard and it's not hard at all. Super easy. You need a t30 torx bit (let me double check that exact size)
    1.take door panel off.
    2.peel back plastic.
    3.take off the three bolts that are in the door jam holding on the actuator
    4.pull the actuator out, trying your best to not bend the metal rods for the pin and the door lock.
    5.Remove the metal rods.
    6.take off electrical clip.
    7. I payed 4.37 for the part compared to the 200
    Win in my eyes. I'm going to put the new one in tonight
  4. #4 Re: Door actuator replacement
    GXP Level Member
    Mar 2015
    Tomball
    Cool did you check it in the yard first?
    Jeff
  5. #5 Re: Door actuator replacement
    i could use a new one for my back pass door, all it did was click so i un plugged it. iirc it was up near the hinge in the door, not a easy area to get to.
  1. Blend Door Actuator Replacement
    By Abrasive in forum How To Write-Ups/Tech Tips
    Last Post: 08-02-2017, 04:59 AM
  2. Vent door actuator
    By Kelly Gould in forum General Grand Prix Discussion
    Last Post: 05-09-2013, 09:46 PM
  3. Blend door or actuator?
    By EJOUIE in forum General Tech Discussion
    Last Post: 05-05-2013, 11:00 PM
  4. Mode Actuator Replacement?
    By GT997 in forum General Tech Discussion
    Last Post: 06-10-2012, 01:32 PM
