Well, I am having a popping issue with the front end on my 07 GP. It only does it when turning left and accelorating or braking. It doesn't matter if you are turning just a little left or even alot left... It doesn't do it when going straight or turning right. (wouldn't be good for NASCAR) If I am going through a slight sweeping left turn and using the brakes or gas, I get a muffled pop pop pop. If I do the same corner in neutral, I get nothing. It funny because if I am turning left and using the gas, I get the pop, pop, pop. Then I hit the brake and get the same pop, pop, pop. The car just hit the 30,000 mile mark. I checked the CV shafts and they both look good with just a touch of in/out movement(car was on lift). The lower ball joints had no play in them. The motor mounts looked good. I checked the cradle bolts and mounts...the appeard to be in good condition and not loose.... Any ideas?
Chris
