Thread: another popping thread....while turning
Results 1 to 11 of 11
cmashark another popping... 01-16-2009, 06:41 PM
WhiteDevil Re: another popping... 01-16-2009, 08:01 PM
cmashark Re: another popping... 01-16-2009, 09:27 PM
The Guz Re: another popping... 01-17-2009, 01:04 AM
cmashark Re: another popping... 01-17-2009, 01:11 AM
cmashark Re: another popping... 01-17-2009, 08:34 PM
cmashark Re: another popping... 04-02-2009, 03:30 PM
WhiteDevil Re: another popping... 04-02-2009, 03:38 PM
cmashark Re: another popping... 04-02-2009, 03:45 PM
WhiteDevil Re: another popping... 04-02-2009, 04:37 PM
cmashark Re: another popping... 04-02-2009, 04:46 PM
  1. #1 another popping thread....while turning
    Jan 2009
    virginia beach
    Well, I am having a popping issue with the front end on my 07 GP. It only does it when turning left and accelorating or braking. It doesn't matter if you are turning just a little left or even alot left... It doesn't do it when going straight or turning right. (wouldn't be good for NASCAR ) If I am going through a slight sweeping left turn and using the brakes or gas, I get a muffled pop pop pop. If I do the same corner in neutral, I get nothing. It funny because if I am turning left and using the gas, I get the pop, pop, pop. Then I hit the brake and get the same pop, pop, pop. The car just hit the 30,000 mile mark. I checked the CV shafts and they both look good with just a touch of in/out movement(car was on lift). The lower ball joints had no play in them. The motor mounts looked good. I checked the cradle bolts and mounts...the appeard to be in good condition and not loose.... Any ideas?
    Chris
  2. #2 Re: another popping thread....while turning
    GTX Level Member WhiteDevil's Avatar
    Aug 2008
    60118 NE Illinois
    Is it a popping or a click/clunk?
    My s-10 did this (4x4) before the entire wheel-well was empty. Ended up being in the front diff where the cv connects to the housing, had a few chewed teeth on the cv spline@ the gears.
  3. #3 Re: another popping thread....while turning
    Jan 2009
    virginia beach
    you feel it more than you hear it....you feel it in the steering wheel. I hope that wheel-well doesn't end up empty! it almost sounds like a faint knocking on wood....not the typical cv clicking.
  4. #4 Re: another popping thread....while turning
    Dec 2008
    Lawndale, CA
    Sounds like a strut mount. I was having the same issue on my 99 when braking and accelerating only. Turned out to be the strut mount. I replaced that and it went away.
  5. #5 Re: another popping thread....while turning
    Jan 2009
    virginia beach
    is there any way to check the mount? I checked the rebound up front and the struts feel very firm..... are there upgrade strut mounts available? I really enjoy driving the car and would like to good parts on her.
    Chris
  6. #6 Re: another popping thread....while turning
    Jan 2009
    virginia beach
    well, I went and picked up a strut mount kit from AA. It was $31.17 with the military discount...I will change it out tomorrow morning. Wish me luck and I will post my results when I am done.
    Chris
  7. #7 Re: another popping thread....while turning
    Jan 2009
    virginia beach
    Well, the strut mounts didn't fix it....neither did both control arms.... any ideas?
    Chris
  8. #8 Re: another popping thread....while turning
    Aug 2008
    60118 NE Illinois
    Ball joints or CV assembly, are your cv boots torn/ripped at all? spread the folds apart and check in the "valley's" of the boot. But this was the end result of my clicking in the front right.
    Id get that front end up and really manhandle to components under there or take it in for a steering/suspension check. My wife was driving when it snapped, As you can see I own a grand prix now.
  9. #9 Re: another popping thread....while turning
    Jan 2009
    virginia beach
    Ball joints are new, they came with the new control arms. The cv shafts and boots "look" good. I gave them a good look over while I was changing the arms.... Its not the typical cv clicking, though. more of a pop pop pop....
    Chris
  10. #10 Re: another popping thread....while turning
    Aug 2008
    60118 NE Illinois
    Caliper bushings?
  11. #11 Re: another popping thread....while turning
    Jan 2009
    virginia beach
    I can even get the car to do it in the driveway with the ebrake set and the wheel turned all of the way to the left, the car in drive, and me pushing on the gas....now I would only use the gas to put the car in tension, but not enough to spin the tires.
    Chris
  1. TCS not turning off
    By Keet04GTP in forum General Tech Discussion
    Last Post: 08-06-2008, 02:57 PM
  2. popping sound when turning...?
    By fst in forum Brakes/Suspension/Chassis
    Last Post: 05-06-2008, 07:49 AM
  3. Popping the hood without the cable.
    By JoshMcMadMac in forum General Tech Discussion
    Last Post: 04-21-2008, 08:38 AM
  4. Speakers Loud Popping
    By GreenNirvana101 in forum Audio, Security & Visual Electronics
    Last Post: 04-02-2008, 10:32 AM
  5. Whats with all these new GP forums popping up?
    By Fish in forum Off Topic Discussion
    Last Post: 12-22-2007, 03:44 PM
