Thread: Speed Daddy Flex Question
Results 21 to 40 of 55
  1. #21 Re: Speed Daddy Flex Question
    Quote Originally Posted by GTP131 View Post
    Sounds like grounds for a dispute or chargeback if they sent you a defective downpipe and blew you off.
    They didn't send me a defective one I just wanted to see if they would sell a new downpipe section as I hit a pothole and punched a nickle sized hole in the sink trap.
  2. #22 Re: Speed Daddy Flex Question
    GTP Level Member bonerjamz03's Avatar
    Apr 2009
    Upper Darby, PA
    Well they just offered to send me a whole new set of headers, I'm guessing they don't have spare parts at their warehouse. I think I'll just take the partial refund and put some rtv on it.
    Btw, does anyone know a cheap catalytic converter that would pass PA inspection?
  3. #23 Re: Speed Daddy Flex Question
    i just installed this one. and passed NJ inspection with it. http://www.ebay.com/itm/360984770059...%3AMEBIDX%3AIT
  4. #24 Re: Speed Daddy Flex Question
    Aug 2013
    McDonald PA
    Quote Originally Posted by bonerjamz03 View Post
    They just look as long as the code is tuned out. No sniffer test
  5. #25 Re: Speed Daddy Flex Question
    Apr 2009
    Upper Darby, PA
    So, I would need an adapter to clamp it to the cat back right?
    Ok, thanks
  6. #26 Re: Speed Daddy Flex Question
    i took the little pipe out of the down pipe, ( the middle pipe) and put the cat there, used 3 inch band clamps and some rtv to make sure it didnt leak, cause its not a perfectly tight fit. i plan to weld it in when i pull the engine. now that i think of it, the right side clamp is covering the the cat and the back reducer pipe butted together because it would not slide on.
  7. #27 Re: Speed Daddy Flex Question
    Aug 2013
    McDonald PA
    Meaning a cat has to be there. So a frozen boost 40 dollar one works.
  8. #28 Re: Speed Daddy Flex Question
    that cat is cheaper then a f/b fake cat, (after you add shipping) and the one i linked fits in the tunnel better.
  9. #29 Re: Speed Daddy Flex Question
    Apr 2009
    Upper Darby, PA
    Alright I'm gonna order that ebay cat. What size adapter 3-->2.5 ?
  10. #30 Re: Speed Daddy Flex Question
    your speed daddy headers have the cat back flange part with the new headers. you just put the cat in place of the short straight pipe.
    its hard to see being so dark and rusty in the pic, but you can see the last header part bolted to the cat back on the far right of the pic.
  11. #31 Re: Speed Daddy Flex Question
    Apr 2009
    Upper Darby, PA
    So I shouldn't need to cut/modify anything?
    Here's my list of stuff for the install.
    SD headers
    ebay cat
    2 - 2.25" clamps
    2 - 3" clamps
    1 - Copper RTV
    Am I missing anything? I recall reading something about a round gasket or something like that. Is that a reusable stock item?
  12. #32 Re: Speed Daddy Flex Question
    your list is good.
    but re use the stock head to header gaskets. use the cat back gasket that comes with the headers. buy 2 new nuts and bolts for the cat back flange as its likely to break or strip and then need to be cut off. not sure if the headers come with them 2 bolts or not.
    i highly recommend a ratcheting box wrench, 13 mm for the manifold bolts in the heads. sockets dont fit well to the nuts or bolts there. but the ratcheting wrench fits like a glove.
  13. #33 Re: Speed Daddy Flex Question
    I think mine came with the bolts.
  14. #34 Re: Speed Daddy Flex Question
    Apr 2009
    Upper Darby, PA
    your list is good.
    I have a set of ratcheting wrenches and they have saved my ass many times lol. Definitely worth the money.
    I should have these installed early next week. After that.....it's pulley time baby.
  15. #35 Re: Speed Daddy Flex Question
    GT Level Member Xorbex's Avatar
    Canada
    I just went through a headache of changing out the sd header to head gaskets as one blew out and the other leaked like a fishing net. As scotty said re-use the stock gaskets there. I also rtv'd the crossover as it was close to leaking with the good stepped band clamps. Also if you plan on keeping your egr then rtv that also or it will leak for sure.
    RIP August 2015 - (2005 Comp G // Custom HAI / S1X Cam / 105 Crow Springs / Mild Ported heads / 3.4 Pulley / SD Headers / Dynomax Catback / Overkill Tune / Comp cams pushrods / LS7 Lifters //)
  16. #36 Re: Speed Daddy Flex Question
    Apr 2009
    Upper Darby, PA
    I think I have to keep the EGR for PA emissions. But yeah I will definitely be using RTV, probably should pick up another tube just in case lol
  17. #37 Re: Speed Daddy Flex Question
    Canada
    one tube is plenty. I probably didnt even use half of mine. Also be careful with the o2 sensor location in the rear header. When test fitting mine i somehow damaged it. It is now welded into the crossover.
  18. #38 Re: Speed Daddy Flex Question
    Apr 2015
    Columbus, OH
    I just installed mine tonight, well the rear head and header. Did you guys have to bend any lines? I had to slightly tweak the ps line and it looks like the transmission dipstick will have to be bent. Haven't put on the crossover, but it looks questionable if it will hit, especially when the clamps on.
    Top Swapped 01 Imp
  19. #39 Re: Speed Daddy Flex Question
    Apr 2009
    Upper Darby, PA
    You guys think I should get this cat welded in before installing?
  20. #40 Re: Speed Daddy Flex Question
    you need to make sure its the right length if you do. if its in the car you cant f it up if you test fit, mark and weld it in.
  1. Wideband question with speed daddy headers.
    By tweeder in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2014, 06:25 PM
  2. xspower or speed daddy headers question
    By BackwoodsEngineering in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-12-2013, 12:42 PM
  3. speed daddy 04+
    By donkason in forum General Tech Discussion
    Last Post: 04-26-2011, 02:24 PM
  4. Speed Daddy headers question
    By 00RegalGS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-14-2010, 09:13 AM
