Thread: Need advice on budging super rusty fuel filter
Results 1 to 20 of 30
  1. #1 Need advice on budging super rusty fuel filter
    GTP Level Member buickman104's Avatar
    NYC
    As the title states. I need advice on budging rusty fuel filter that is clogged on rusty 2000 Bonneville. Soaked the line nut in pb blast for two nights prior to removal attempt. Got under the car and was unable to even budge it. being a fuel line obviously I couldn't hit it with heat to soften the metal. Any advice on removing the filter would be appreciated.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  2. #2 Re: Need advice on budging super rusty fuel filter
    vise grip in the line nut, hold the line nut still, and then use a another wrench to turn the filter off the nut.
    dont turn the line nut or the line will twist and then your patching it up for sure.
  3. #3 Re: Need advice on budging super rusty fuel filter
    Mar 2012
    NC
    ^^^THIS.
  4. #4 Re: Need advice on budging super rusty fuel filter
    NYC
    Tried that. It wouldn't budge.
  5. #5 Re: Need advice on budging super rusty fuel filter
    Buffalo
    Lol heat it up .....
    j/k
    honestly drop it off at Firestone or somewhere. Pay the $40 - let them deal with it
  6. #6 Re: Need advice on budging super rusty fuel filter
    hangover park IL
    Torch
    ~James~ Psychotic Gearhead
  7. #7 Re: Need advice on budging super rusty fuel filter
    St. Louis
    It'll come off. Sounds like you need more leverage than the standard wrench is giving you. Keep hitting it with PB.
  8. #8 Re: Need advice on budging super rusty fuel filter
    Walk away, it's a 3800, I have proven the fuel filters to be good for over 260K
  9. #9 Re: Need advice on budging super rusty fuel filter
    SE Level Member mrpopo's Avatar
    Aug 2014
    New Jersey
    The Fuel Filter in question is on my car. I only let buickman104 go at it when I got scared that I was about to break the fuel line. The only other option I thought about was using a wirebrush to clean up the nut a bit, and then hitting with PBlast.
    2000 Bonneville SSEi 160k-ish Miles.
    Gen5 S/C, ZZP Powerlog, ZZP downpipe, ZZP 1.0 PCM, 3.6 Pully, Lucas 42.5 Injectors, N* Throttlebody, Hot Air intake, F-body Brakes
  10. #10 Re: Need advice on budging super rusty fuel filter
    St. Louis
    Couldn't hurt. Would let the PB get further into the threads.
  11. #11 Re: Need advice on budging super rusty fuel filter
    hangover park IL
    Torch it
  12. #12 Re: Need advice on budging super rusty fuel filter
    Aug 2014
    New Jersey
    Dunno man, your notion of fire on a fuel line makes my spidey sense tingle... and not in a good way.
  13. #13 Re: Need advice on budging super rusty fuel filter
    Only way to get an ugly one off w/o hurting the line is to turn the filter and hold the line/fitting solid. When all else fails... turning the radio up and realizing that I've tested the limits of a fuel filter is the way to go.
    Ask Antonio, He'll tell you. BTW, thanks for moving and having him in NJ as often as you have. Helped me out with him looking at a car.
  14. #14 Re: Need advice on budging super rusty fuel filter
    hangover park IL
    Buncha pussies
  15. #15 Re: Need advice on budging super rusty fuel filter
    Buffalo
    ^ right? Lol
  16. #16 Re: Need advice on budging super rusty fuel filter
    Apr 2015
    Columbus, OH
    Cut it off and buy a repair kit. What I did. Was just going to leave it on but just the little bit of messing with it caused a pin hole leak where it was rusted.
    Brake lines are next.
    Top Swapped 01 Imp
  17. #17 Re: Need advice on budging super rusty fuel filter
    Holy rust lol
    04 Comp G.
  18. #18 Re: Need advice on budging super rusty fuel filter
    Apr 2015
    Columbus, OH
    Holy rust lol
    You like that? Here another money shot for ya then:
    Top Swapped 01 Imp
  19. #19 Re: Need advice on budging super rusty fuel filter
    NYC
    Might you happen to have a link to the repair kit you used?
    Quote Originally Posted by bandook View Post
  20. #20 Re: Need advice on budging super rusty fuel filter
    Apr 2015
    Columbus, OH
    Quote Originally Posted by buickman104 View Post
    They sell them at Advance. Just a 18" line with fitting for filter on one end, and a compression fitting for where you cut in. Like 18 bucks I think.
    Like this.
    Top Swapped 01 Imp
  1. Rusty Fuel Filter YYYAAAHHH!
    By rell2005 in forum General Tech Discussion
    Last Post: 11-18-2013, 11:14 AM
  2. Rusty Fuel Filter YYYAAAHHH!
    By rell2005 in forum General Grand Prix Discussion
    Last Post: 10-09-2013, 07:51 PM
  3. sluggish / misses / dies / did tune up w fuel injection / did fuel filter / car runs
    By dlc723e in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-30-2012, 08:25 PM
  4. Changed Tranny Fluid/Filter, Fuel Filter Tonight
    By nickbuol in forum General Tech Discussion
    Last Post: 10-15-2010, 06:04 PM
