Thread: How am I looking for a pulley drop? (HPT scan log included)
Results 1 to 17 of 17
  1. #1 How am I looking for a pulley drop? (HPT scan log included)
    SE Level Member Centauri's Avatar
    Sep 2014
    St. Paul, MN
    Mods in my signature are already done. I'm just waiting for Reptile's tune to arrive, and I know tunes tend to help drop KR a little bit.
    Anybody care to take a gander at my scan log? https://onedrive.live.com/redir?resi...int=file%2chpl
    Thanks.
    1999 Grand Prix GTP sedan
    Speed Daddy headers, 3.25" on a ZZP MPS, high-flow cat, 180
    ° t-stat, Autolite copper 104s, shift kit, ReptileTune...
  2. #2 Re: How am I looking for a pulley drop? (HPT scan log included)
    Kemmerer, Wyoming
    did you drive for more than five minutes to take this scan? a scan log is useless unless you drive around for a while.
  3. #3 Re: How am I looking for a pulley drop? (HPT scan log included)
    Sep 2014
    St. Paul, MN
    It was probably about 15 minutes and I tried to work in some WOT. I mean, we're scanning for KR not trying to do a MAF tune.
    Is there a technique to this that's explained somewhere? I could have done more cruising around but I don't knock at cruise.
  4. #4 Re: How am I looking for a pulley drop? (HPT scan log included)
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    Best way it to get a few driving conditions in it. Roll into it a few times all the way to wot. Then I like to catch a few 4-2 and 3-2 WOT shifts and run it to about 100. Basically top of second til a few moments after shift to 3rd. I don't run my scans too far into 3rd WOT cause I run 2nd to about 100.
    But to your original question, your scans look ok. Drop it down and scan all the time. If you see too much knock, pulley back up.
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  5. #5 Re: How am I looking for a pulley drop? (HPT scan log included)
    Kemmerer, Wyoming
    I only saw one scan and it didn't go above 20% throttle, so I'm not sure if I'm looking at the scan you intended to post.
  6. #6 Re: How am I looking for a pulley drop? (HPT scan log included)
    Mar 2014
    Tucson
    Quote Originally Posted by SgtMarshal View Post
    Must have been looking at something else.
  7. #7 Re: How am I looking for a pulley drop? (HPT scan log included)
    Jan 2013
    Raleigh, NC
    Damn I missed that knock. Jesus.
  8. #8 Re: How am I looking for a pulley drop? (HPT scan log included)
    stock pulley headers and 5.8 kr? check to see if the o2 sensor is hitting, or the down pipe hitting the sway bar.
  9. #9 Re: How am I looking for a pulley drop? (HPT scan log included)
    Sep 2014
    St. Paul, MN
    Got around to an exhaust shop today to repair something else and took a look at the o2 while I was down there; it's definitely hitting. The friend I had install my headers didn't even dent in the floor pan so the sensor is rammed into it to the point of being bent at the end. So the only way to undo it is to cut is out, re-weld the bung elsewhere and pop in a new sensor.
    *sigh*
    Pardon my ignorance though, but would somebody mind explaining to me how the o2 making contact with the floor pan contributes to engine knock? Not arguing the point, I just can't figure out. And there aren't any codes related to the sensor.
    Thanks peeps.
  10. #10 Re: How am I looking for a pulley drop? (HPT scan log included)
    Mar 2012
    NC
    Quote Originally Posted by Centauri View Post
    *sigh*
    Thanks peeps.
    The vibrations of the O2 hitting the floor are picked up by the knock sensor which means the engine pulls timing to get it to stop.
  11. #11 Re: How am I looking for a pulley drop? (HPT scan log included)
    you can hammer the firewall to clearance it for the o2. a air hammer makes it easy with the header in still.
  12. #12 Re: How am I looking for a pulley drop? (HPT scan log included)
    Sep 2014
    St. Paul, MN
    They want $75 to cut it out and weld a new bung or $75 to cut it out and hammer in the firewall. I reckon the weld is the better option.
  13. #13 Re: How am I looking for a pulley drop? (HPT scan log included)
    sounds like the asshole shop im stuck with. they wanted 75 to weld a bung in the crossover. i took the pipe off and gave then just the pipe with a X marked on it, drill and weld bung here, 30 bucks lol
  14. #14 Re: How am I looking for a pulley drop? (HPT scan log included)
    If your wideband thing on that screen shot is correct, you are way lean. 12.6 afr is kinda dangerous.
    And if you arent going to log injector bank 2 and the rear o2 sensor, remove those from the 3rd table and add commanded AFR to that. You will want to know what the PCM is commanding for fuel.
  15. #15 Re: How am I looking for a pulley drop? (HPT scan log included)
    Sep 2014
    St. Paul, MN
    Might it be because the o2 is rammed into the firewall? Or is this something else entirely?
  16. #16 Re: How am I looking for a pulley drop? (HPT scan log included)
    Doubtful.
    I can't see your tune nor can I see the commanded AFR on that screen shot. So if you are commanding mid 12's and the wideband shows mid 12's, thats part of the problem. Or if you see 12.6 on the wideband and you are commanding 11.5, thats another problem. Adjustment would need to be made there to give it more fuel.
  17. #17 Re: How am I looking for a pulley drop? (HPT scan log included)
    Sep 2014
    St. Paul, MN
    I've got a Reptile tune going in tomorrow so hopefully that corrects things. We'll see.
  1. pulley drop
    By SgtMarshal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-17-2014, 11:41 PM
  2. 3.4 pulley drop
    By hollas13 in forum General Tech Discussion
    Last Post: 07-18-2013, 08:36 AM
  3. Should i drop to a 2.8 pulley?
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-03-2013, 12:43 PM
  4. Pulley drop
    By deejayfb in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-18-2011, 10:52 PM
  5. pulley drop 05
    By wlmrt6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-27-2010, 07:51 AM
