Thread: pulley drop 05
Results 1 to 5 of 5
  1. #1 pulley drop 05
    GT Level Member wlmrt6's Avatar
    Sterling
    I have an 05 gtp and im thinking about dropping to a 3.6 pulley. i will be getting an intake a zzp 3" downpipe wiht high flow cat, 180* tstat, ngk 1 degree colder plugs, and an intense racing tune. what pulley should i get to where i dont have to rent a tool to put it on or take it off??? also would like to know what brand of pulley is better? and will i need a new belt?
  2. #2 Re: pulley drop 05
    Portland Oregon
    First thing, a little food for thought. I have an 04 gtp with headers, open cone intake, autolite 104's (two heat ranges colder), a tune, a 180 stat, and a 3.6 pulley. I still see up to 3-4 degrees of kr when I race at the track at times. I don't think you should pulley down with any less of a mod list than I have. I'm going to rocker it soon with some 1.95's and see if it'll take a 3.4. If not I'm intercooling. As far as pulley brand, I run a pulley boys pulley. Intense or zzp pulleys are good too.
  3. #3 Re: pulley drop 05
    ZZP and intense are best to start with because they are easiest to find used.
  4. #4 Re: pulley drop 05
    Charles City, IA
    FYI intense and zzp pulleys are interchange able.
    SMGPFC Two Nipple General
  5. #5 Re: pulley drop 05
    Donating Users dirtmaster88's Avatar
    Sheboygan, WI
    Quote Originally Posted by OH4CompG View Post
    X2
    I also have those exact mods and also see that much knock.
    2004 GTP CompG - 3.6" ZZP MPS, K&N CAI, 180* Tstat, SSAC Headers, ZZP Flex, high flow cat, borla exhaust, DHP/danthurs tune, AL104s, ZZP Wires, alt re-wire, slotted/drilled rotors, 35% tint, alpine amp + sub
  1. pulley drop question
    By blwn3800 in forum General Tech Discussion
    Last Post: 11-18-2009, 06:43 PM
  2. MPG Drop
    By 2k6GT in forum General Tech Discussion
    Last Post: 08-14-2009, 11:56 PM
  3. I wanna drop to a 3.0 pulley OPINIONS PLEASE
    By Uno99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2009, 10:34 PM
  4. power drop
    By Toasty in forum General Tech Discussion
    Last Post: 03-18-2008, 07:36 PM
