Thread: High beams will not come on
Results 1 to 16 of 16
  1. #1 Re: High beams will not come on
    Apr 2015
    Michigan
    Quote Originally Posted by luckyg817 View Post
    Do you have a multimeter? Check for power at the connectors for the hi beams. If you don't have any power, you probably have a bad connection somewhere or something isn't plugged in right.
    No, but I can get one quick.
    Measuring at one hi beam connector might not tell the whole story though. I'm wondering if there is a connector somewhere that the signal gets split to each side (driver/passenger)...that would more likely be the culprit.
    Looks like I'm going to be putting my detective hat on and go hunting...
  2. #2 Re: High beams will not come on
    Aug 2013
    arlington, tx
    Quote Originally Posted by jjaaam View Post
    Verifying that you have no power at the hi beam connectors will confirm that your bulbs are fine and you just need to trace back from there where the break in the circuit is.
  1. 05 gtp lows beams stay on with high beams.
    By pontiacGTP123 in forum General Tech Discussion
    Last Post: 06-15-2014, 01:24 PM
  2. High Beams
    By 2coolit in forum Audio, Security & Visual Electronics
    Last Post: 12-17-2013, 11:07 AM
  3. high beams.
    By gunsn88 in forum General Grand Prix Discussion
    Last Post: 01-14-2012, 03:44 PM
  4. Fog lights on with high beams.
    By BackInBlack in forum How To Write-Ups/Tech Tips
    Last Post: 08-15-2010, 05:30 PM
  5. No High Beams
    By taximech in forum General Tech Discussion
    Last Post: 06-23-2009, 11:37 AM
