Thread: MAF Low Voltage
Results 1 to 8 of 8
  1. #1 MAF Low Voltage
    Oct 2014
    St Augustine FL
    I just got an SES light with a MAF low voltage code today on my way home from work. I cleared the code and it did not return aft driving 10 miles. Is it worth trying to clean the sensor? Any other ideas. The car ran pretty normal. Although, it did stumble a little under light acceleration a couple times.
  2. #2 Re: MAF Low Voltage
    Sure you can clean it, but I'd be looking into a possible wiring issue if it comes back.
  3. #3 Re: MAF Low Voltage
    GTP Level Member Kaiser Pontiac's Avatar
    Jun 2015
    Land of 10,000 Salted Roads and Rusty Cars.
    http://easyautodiagnostics.com/gm/3....nostic-tests-1
    Was a great help when I had a P0102, ended up with a bad MAF, bad MAF to PCM wire, and having a melted O2 harness. I probably had worse symptoms though; 12/13 mpgs, white smoke, coughing acceleration, reving idle, ect.
    06 LaCrosse 57-79k sold;99 4dr GTP 134-138k sold;98 2dr GTP 183k parted;98 Regal 166-184k;04 GT2 204-206k sold;04 GTP 170-175k sold;09.5 G8 GT Sport 145k;09 G8 78-84k+;08 Prix 164k sold;06 Prix 168k sold;02 Regal 92k;09 G8 103k parted;04 GTP SpEd 139k parted;04 GTP 205k;'09 G8 105k parted;06 Prix 230k;04 CompG 138k
  4. #4 Re: MAF Low Voltage
    Oct 2011
    Toledo, OH
    I had that a few months ago. After purchasing 2 MAFs and the problem still coming back after a week I found out my connector pins on the harness were corroded. Cleaned them up, add some dielectric grease and the problem hasn't came back.
    7"
  5. #5 Re: MAF Low Voltage
    Oct 2014
    St Augustine FL
    I bought a new MAF sensor and the problem seems to be fixed.
    I tried cleaning the old sensor and I checked the wiring before and that did not help.
  6. #6 Re: MAF Low Voltage
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    Quote Originally Posted by 02GTPJeff View Post
    I was going to send you the one I had for the cost of shipping your lose I guess.....
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  7. #7 Re: MAF Low Voltage
    Oct 2014
    St Augustine FL
    Quote Originally Posted by Tonkin2000GT View Post
    Thanks anyway. Didn't realize you intended to send for cost of shipping only. I bought one off Amazon for $32. Hopefully, it will hold up fine.
  8. #8 Re: MAF Low Voltage
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    I'm putting money on that that is not an AC-Delco MAF if you got it that cheap. Cheap is not your friend when it comes to MAF's. So don't expect that thing to work/fix your problem. I'd buy Tonkins right away assuming it's an OEM one.
  1. Low Voltage
    By akarana23 in forum General Tech Discussion
    Last Post: 07-14-2013, 10:00 AM
  2. Voltage problem?
    By Dallasneon in forum General Tech Discussion
    Last Post: 07-13-2013, 09:32 AM
  3. low voltage
    By stonecold0469 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-07-2012, 10:19 PM
  4. No Voltage at PCM
    By tdenstedt in forum Introductions/Noob Questions
    Last Post: 04-22-2011, 09:08 AM
  5. Low Voltage
    By Wakeboy1337 in forum General Tech Discussion
    Last Post: 02-12-2011, 03:24 PM
