Thread: High beams will not come on
Results 1 to 16 of 16
Threaded View
  1. #4 Re: High beams will not come on
    Apr 2015
    Michigan
    OK...
    Took out a different relay per FFDP's post and tried it. No change. One thing I DID notice however was that I could hear the relay clicking when I used the multi-function switch to turn the hi beams on. I put the original relay back in and heard the same clicking...so the relay must not be the issue.
    Checked fuses for hi beams as well and all was good.
    Is it really possible that BOTH hi beam bulbs blew out at exactly the same time? I would think that would be kind of odd...but at this point I guess it could be a possibility.
    Also, are the low beams supposed to go off when the hi beams are on? Because if they are, they don't. They stay on just like I never tried to turn the brights on. The only way I know is the little blue hi beam indicator is on. They don't flicker or anything...just stays on low beams all of the time.
    Any other ideas?
  1. 05 gtp lows beams stay on with high beams.
    By pontiacGTP123 in forum General Tech Discussion
    Last Post: 06-15-2014, 01:24 PM
  2. High Beams
    By 2coolit in forum Audio, Security & Visual Electronics
    Last Post: 12-17-2013, 11:07 AM
  3. high beams.
    By gunsn88 in forum General Grand Prix Discussion
    Last Post: 01-14-2012, 03:44 PM
  4. Fog lights on with high beams.
    By BackInBlack in forum How To Write-Ups/Tech Tips
    Last Post: 08-15-2010, 05:30 PM
  5. No High Beams
    By taximech in forum General Tech Discussion
    Last Post: 06-23-2009, 11:37 AM
