Thread: Thinking of buying a spare. motor to build
Page 3 of 3 FirstFirst 123
Results 41 to 57 of 57
  1. #1 Re: Thinking of buying a spare. motor to build
    GXP Level Member
    Mar 2015
    Tomball
    Sven,
    That at makes more sense. Basically it boils down to improper attention to detail. I'm not new to engine building so I do understand proper procedures. I just think that in the technical forum should have higher standards. Discussion from knowledgeable people about the subject in question. You have a guy that wants to know manifold air temp which I think is a valid question and I would think that as long as these cars have been out you guys would have all kinds of data. There isn't, he basically gets laughed off the board. When you are trying to get the most out of any engine you need to know everything going on. Guessing is grenading is what I like to say.
    I'm not planning a rebuild. If got to figure out why it's not running right first. (Suspected Knock sensor)
    Jeff
  2. #2 Re: Thinking of buying a spare. motor to build
    May 2012
    Where winter never ends
    ZZP and stattama made the 8 sec stock block car. Stattama.com has pictures and build info. intense s4 heads, stattama turbo cam, stock l67 bottom end.
    2000 Regal - Winter Beater
  3. #3 Re: Thinking of buying a spare. motor to build
    SE Level Member Lil larry's Avatar
    Nov 2012
    Elkview, west virginia
    Maybe I should've been a little more clear I'm buying the spare basically to regasket and put a cam,heads ect on
  4. #4 Re: Thinking of buying a spare. motor to build
    you mean something like this? lol
    my 109.000 new to me n/a. just spent 220 in fluids and gaskets, once i get the s/c heads ported ill rip it down and get to swapping all its gaskets.
  5. #5 Re: Thinking of buying a spare. motor to build
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    Just throwing this out there,seems how people with rebuilds never do usually post back.I'm going on 15k with my rebuild in my GTP,as stated before,it can be done if it's done properly.But it does cost roughly 2 grand to do it properly.The line boring of the mains is a huge part, but so is having a round big end on the rods.That's what screws a lot of people as well,having oblonged big ends.Can't half ass rebuild these and get away with it most of the time.
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  6. #6 Re: Thinking of buying a spare. motor to build
    GXP Level Member
    Mar 2015
    Tomball
    Engines are a lot more precision these days than in days past. A lot of material is removed to save weight, so I could see it being an issue for joe shade tree. Any engine that makes more HP than displacement needs proper machining and checking. I check a minimum of 4-6 points per journal. Have the big end resized and line bored if needed. Bores are checked in a minimum of 6 places. Building an engine for a car like this should be part of the fun. If this is your daily driver the. Drop a short block in it and drive on. I just wanted the discussion to go farther than "it's not possible, you'll blow it up.
    Jeff
  7. #7 Re: Thinking of buying a spare. motor to build
    Sep 2014
    Worcester, MA
    To me, it sounds a LOT cheaper to rebuild your motor correctly than to:
    1) Buy a used engine for $500
    2) After installing it, find out that it has a rod knock
    3) Getting another engine for $500
    4) Having it break down after 10k miles
    5) Getting fired because you are always missing work because of car problems
    6) Getting divorced because you spend all of your weekends away from your family in the garage, missing time with your kids, and constantly whining about how much bad luck you always have with the car
    etc...
    If checking the rod big ends and align boring are all that's "tricky" or "difficult" about rebuilding a 3800, then for me it's a no brainer - I'm spending the $2k on rebuilding!
  8. #8 Re: Thinking of buying a spare. motor to build
    Mar 2012
    NC
    Quote Originally Posted by bobc455 View Post
    etc...
    Let me know how well that $2k holds up against a $500 used engine. Because chances are, unless you've done it a bunch of times (or whoever is doing the machine work,) it's gonna be a short lived rebuild. I have tons of engine machining experience, had a full machine shop, and still went with a used block vs rebuild. Why? Because L36 and L67 blocks have been known to go well over 300k when properly maintained. I've done the $500 (or less) engine swap on a lot of cars...not just 3800 powered. I've had worse luck with used 98-03 Honda/Isuzu 3.2L V6 than 3800.
  9. #9 Re: Thinking of buying a spare. motor to build
    Getting a bad used engine is still cheaper. Ky engines are warranted for six months. And a full proper rebuild is still 2500 bucks.
  10. #10 Re: Thinking of buying a spare. motor to build
    hangover park IL
    yeah...until you price out a new gm crank....or you could get a reman crank....and have it snap on you and destroy 2k worth of parts.
    even if your rebuilding....you need to get a good used engine anyways to have a good crank and good rods. cant resize the PM rods without expensive oversize shell bearings.
    i believe eric still has his custom 4500$ two piece crank.
    biggest problem is these engines are not designed for std babbit bearings, they only last when the aluminum bearings are in em.
    the std oiling system mods dont hurt ether
    ~James~ Psychotic Gearhead
  11. #11 Re: Thinking of buying a spare. motor to build
    Buffalo
    Read this thread to see why rebuilding the block isn't as easy as some think http://www.3800pro.com/forum/superch...900-kit-2.html
  12. #12 Re: Thinking of buying a spare. motor to build
    Quote Originally Posted by crazyguy03 View Post
    Like I just posted in the chatbox.
    It's simple as any other bare engine. It just takes the proper machine work, that most don't do.
  13. #13 Re: Thinking of buying a spare. motor to build
    GT Level Member MyLittlePony's Avatar
    Mar 2015
    Franklin, TN
    That is good stuff, if it ain't properly machined it is wrong.
  14. #14 Re: Thinking of buying a spare. motor to build
    GXP Level Member
    Mar 2015
    Tomball
    Quote Originally Posted by ls1adam84 View Post
    That's quite correct, and just because you have someone machine your parts doesn't mean they did it correctly, that's where verifying everything after you get the parts back and inventory them. If they ain't right you have it done again if possible or you make them replace the part corrected to your specs they were given. If you don't have the tools to check this and ensure you are getting what you need to balance and blueprint the engine then don't touch it. But for those of us that do don't tell us you can't rebuild an engine without giving a reason, we will think that you don't know what you are talking about. Taking an engine apart and putting it back together isn't rebuilding an engine at best it's an inspection, at worst it's a disaster.
    Jeff
  15. #15 Re: Thinking of buying a spare. motor to build
    Buffalo
    It is what it is
  16. #16 Re: Thinking of buying a spare. motor to build
    Mar 2015
    Franklin, TN
    Or is it?
  17. #17 Re: Thinking of buying a spare. motor to build
    redneck tennessee
    Turbocharged400sbc is right, I had to get a junkyard motor for a crank, bought new pm rods,and I'm running aluminum bearings.Why the vendors all sell steel I haven't a clue.Doing it like this definitely isn't economical,lol.But it's part of why mines lasting.
  1. Thinking about buying a gtp.
    By justin1795 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-20-2010, 10:46 AM
  2. Thinking of buying a 06' gxp
    By Hawkins04 in forum Off Topic Discussion
    Last Post: 12-27-2009, 09:26 PM
  3. thinking about buying a 98 with a bad motor
    By allensteiner21 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-15-2009, 09:21 AM
  4. Thinking about buying 07 or 08 GP
    By sn95gt50 in forum Audio, Security & Visual Electronics
    Last Post: 04-13-2009, 08:08 PM
