Thread: Thinking of buying a spare. motor to build
Results 1 to 20 of 57
  1. #1 Re: Thinking of buying a spare. motor to build
    GT Level Member MyLittlePony's Avatar
    Mar 2015
    Franklin, TN
    That is good stuff, if it ain't properly machined it is wrong.
  2. #2 Re: Thinking of buying a spare. motor to build
    GXP Level Member
    Mar 2015
    Tomball
    Quote Originally Posted by ls1adam84 View Post
    That's quite correct, and just because you have someone machine your parts doesn't mean they did it correctly, that's where verifying everything after you get the parts back and inventory them. If they ain't right you have it done again if possible or you make them replace the part corrected to your specs they were given. If you don't have the tools to check this and ensure you are getting what you need to balance and blueprint the engine then don't touch it. But for those of us that do don't tell us you can't rebuild an engine without giving a reason, we will think that you don't know what you are talking about. Taking an engine apart and putting it back together isn't rebuilding an engine at best it's an inspection, at worst it's a disaster.
    Jeff
  1. Thinking about buying a gtp.
    By justin1795 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-20-2010, 10:46 AM
  2. Thinking of buying a 06' gxp
    By Hawkins04 in forum Off Topic Discussion
    Last Post: 12-27-2009, 09:26 PM
  3. thinking about buying a 98 with a bad motor
    By allensteiner21 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-15-2009, 09:21 AM
  4. Thinking about buying 07 or 08 GP
    By sn95gt50 in forum Audio, Security & Visual Electronics
    Last Post: 04-13-2009, 08:08 PM
