Thread: pcm/wiring engine swap questions
Results 1 to 5 of 5
  1. #1 pcm/wiring engine swap questions
    GT Level Member Shiftingshaddow's Avatar
    KC
    Well i came across a 500 dollar roller gtp on cl with headers and exhaust that i want out of it. car appears to be in good shape. its a 2000.
    now, my father in law has a century he claims has a 3800 in it but my bro in law wrecked it. im not really sure if that was an engine option or not for that car. i think its a 2000. anyway, the engine and transmission are good.
    i know that the engine and transmission will drop right into the gtp. here is the question......
    how is this going to work with a gtp dash? the pcm will be from the century. the wiring harness will be from the gtp. would the wiring harness have to come out of the century with the car and go in the gtp?
    are there any other modifications i could be missing? this is assuming its a 3800.
    2001 GTP Special Edition
    ZZP DP with Cat, Open Cone Intake, ZZP 1.0 PCM, 3.4 pulley, AL 104s, Rocker Panel Delete.....
  2. #2 Re: pcm/wiring engine swap questions
    KC
    or lets think about this......
    what would need to be changed to put a 2001 gtp motor and transmission into a 2000 body?
  3. #3 Re: pcm/wiring engine swap questions
    The Century, to my knowledge only ever had the 3.1 motor in it. I never paid a lot of attention to them though, so maybe 3.8 was an option. You don't mention the year of the Century, so ... that makes it a little tough. Essentially though, I'd get a pcm programmed for the NA motor and whichever trans you choose. Keep the GTP wiring harness and pcm. It's almost everything you would need.
    01 in 00. Drop it in and hook it up on the 00 harness/pcm
  4. #4 Re: pcm/wiring engine swap questions
    KC
    Thanks billboost. I think he is mistaken and the century is the 3.1.
  5. #5 Re: pcm/wiring engine swap questions
    Regal looks just like a century though
  1. wiring questions
    By python1986 in forum Introductions/Noob Questions
    Last Post: 03-01-2013, 12:04 PM
  2. Engine swap questions need help.
    By Utter99 in forum General Grand Prix Discussion
    Last Post: 06-01-2012, 06:20 AM
  3. Engine swap questions.
    By TacomaBonne in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-30-2011, 05:45 AM
  4. engine swap questions
    By chrisgsx in forum General Tech Discussion
    Last Post: 02-19-2011, 01:21 PM
  5. Need some help, wiring harness meltdown! have some harness swap questions for a guru
    By pureroundcircle in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2011, 09:23 PM
