Thread: Supercharger Bypass Actuator?
Results 1 to 8 of 8
  1. #1 Supercharger Bypass Actuator?
    Aug 2011
    Birmingham, AL
    97 GTP, noticed that the nipple for the vacuum line on the supercharger bypass actuator coming from supercharger bypass solenoid is broken off. Anyone know where to get a replacement? Part #?
  2. #2 Re: Supercharger Bypass Actuator?
    Aug 2011
    Birmingham, AL
    Looks like it has to be ordered from zzp
    Is it possible to glue the hose on for now somehow until the part arrives?
  3. #3 Re: Supercharger Bypass Actuator?
    Apr 2011
    Elk Rapids, Michigan
    Many unplug that port anyway. The solenoid cuts the boost and keeps the bypass valve open when your traction control kicks in from reduced traction being detected. If you don't care about that then you can still drive the car and order a replacement if you want. Junk yard may be a good place to pick one up cheaper then ZZP or the dealer.
    2001 black GTP coupe, Gen V, ZZP S2IC & billet fuel rails, XP cam, LS7 lifters, 105# springs, ZZP MPS w/3.4 pulley, Northstar tb, LQ4 maf, ZZP headers, K & N CAI, Meziere electric wp, Caspers fp retire, F body front brakes, GMPP strut braces​, Don Rome strut brace mounts.
  4. #4 Re: Supercharger Bypass Actuator?
    Aug 2011
    Birmingham, AL
    Just so we're clear, the broken nipple is marked with the red X on this diagram.
    http://m.imgur.com/HYVzMf7
  5. #5 Re: Supercharger Bypass Actuator?
    Kemmerer, Wyoming
    your best bet is to take the vac line off that runs to the BBV solenoid and unplug the solenoid. all the BBV and the BBV solenoid do is cut boost when in reverse and when the wheels are spinning. its not necessary. here is a picture of how mine looks:
    the first picture is how it should look when you do the BBV solenoid delete, there are other's that I took before I figured out the right way to do it.
    http://i1115.photobucket.com/albums/...ps0f27a8d6.jpg
  6. #6 Re: Supercharger Bypass Actuator?
    Aug 2011
    Birmingham, AL
    This wouldn't have anything to do with my awful mileage would it?
  7. #7 Re: Supercharger Bypass Actuator?
    Kemmerer, Wyoming
    it could if you have a vacuum leak. any unmetered air coming in is going to make your car run rich to compensate.
    try doing the BBV solenoid delete and see if it makes a difference
  8. #8 Re: Supercharger Bypass Actuator?
    GT Level Member QuinlanGTP's Avatar
    Apr 2014
    Chicopee,MA
    Is the pic with the T and the bolt in line how it should look? Im about to do this to my car and wasn't sure.
    1998 GTP (COUPE)-160K - Ram Air hood,CAI,SD Headers, Transgo kit, Scotty tune
    2000 GTP (4DOOR)-140K - Gone 2000 GTP (COUPE) - 300K+- Gone now
  1. Boost a bit low, how to test the boost bypass solenoid & actuator?
    By Elite6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2014, 07:50 PM
  2. Boost Bypass Actuator
    By fri3dchick3n in forum General Grand Prix Discussion
    Last Post: 08-14-2013, 05:47 PM
  3. Supercharger bypass solenoid and bypass actuator question
    By 2004blackgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-07-2013, 04:46 PM
  4. Need help!~ with bypass valve boost actuator
    By dreama in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2012, 09:22 AM
  5. Supercharger ACTUATOR???
    By PTGsDaytona500GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-27-2012, 08:25 PM
