Thread: engine stalls
Results 1 to 20 of 21
  1. #1 engine stalls
    May 2008
    Winnipeg, MB
    Was driving home from work tonight and the engine stalled. Electrical system was still going. Coast to a stop, put it in Park, restart the car and continue to drive then it did this again. No error codes show up with Torque App, no check engine light or message on the DIC. Not sure where to begin to figure this out.
    2007 Pontiac Grand Prix
  2. #2 Re: engine stalls
    Feb 2013
    37.295091, -121.930053
    check your battery connection or alt connection hell even your ignition switch could be faulty.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: engine stalls
    most of the time thats a crank sensor. they hardly ever set the cel.
  4. #4 Re: engine stalls
    May 2008
    Winnipeg, MB
    is that expensive to replace?
  5. #5 Re: engine stalls
    GTP Level Member
    Oct 2014
    My bad ICM acted like that also without setting any code. Damn engine was so smooth you hardly knew it shut off.. I had to wiggle the wires on the ICM to get it to start every once in a while also.
    Sent from my iPad using Tapatalk
  6. #6 Re: engine stalls
    May 2008
    Winnipeg, MB
    is there a way to test the crankshaft position sensor?
    just drove the car for an hour and no issues
  7. #7 Re: engine stalls
    keep driving it like normal. try to keep note if the tach is working all the time, if it stops working, or drops to zero when it stalls thats a crank sensor.
  8. #8 Re: engine stalls
    May 2008
    Winnipeg, MB
    It did that when it stalled but what else would the tach do if there is no engine power?
  9. #9 Re: engine stalls
    Sep 2014
    Worcester, MA
    If the crank sensor is functioning correctly and there is a different issue, chances are the tach will not drop to 0 until the engine actually stops running.
    If the crank sensor has failed, the tach will immediately drop to 0 and the computer will think the engine isn't running, and will stop supplying fuel.
    Kinda a chicken-and-egg thing, but the tach will be your best clue.
  10. #10 Re: engine stalls
    May 2008
    Winnipeg, MB
    Oh I get it now. I need to keep a close eye on the tach and if it drops to zero BEFORE the engine stalls then its the crank sensor. Seems like there would only be a short period of time between the two events happening.
  11. #11 Re: engine stalls
    if your rolling in gear stalled out, the engine is still turning via the tranny. and the tack will still be working.
    if its the crank sensor the tach will be flat on zero while rolling in gear when it stalls. or you may see it at zero way before that car stalls.
  12. #12 Re: engine stalls
    May 2008
    Winnipeg, MB
    Bradley Tod
    Driven the car twice now and has not done it again. So frustrating because I have time off from work to deal with this but if it don't keep happening soon I will just let it go until it happens again.
    Like · More · Just now
  13. #13 Re: engine stalls
    they suck like that. can act up all day long one day, then not at all the next. when it stalls and fails to start back up right away thats also a good sign its the crank sensor. they can sometimes take 15 minutes, then longer, then like a week of trying. most call a tow truck, then it fires up as the truck comes takes it, or fires up when it gets to your house or shop.
    when my icm was acting up it would misfire a bit then stall, but the tack kept rolling at 1700 rpm. that did toss a icm code after the second stall out.
  14. #14 Re: engine stalls
    May 2008
    Winnipeg, MB
    Update:
    Did this to me again yesterday. Yes the tach reads 0 while coasting to a stop. Also the car started with a veery ruff idle that went away after a minute or so then ran fine until it stalled about 5 minutes later while driving.
    Can I get a idea what a shop will charge to fix this? like how many hours of labour they will charge for? to replace the crankshaft position sensor
  15. #15 Re: engine stalls
    Sep 2014
    Worcester, MA
    Quote Originally Posted by tod1d View Post
    That's not the question. I apologize for being unclear.
    Which goes to 0 first? the tachometer, or the actual engine RPM?
    Maybe someone else can help me word my question better. I don't care about the car coasting to a stop, I'm only interested in whether the tach drops to 0 before the engine actually stops.
    (If the crank sensor is failing, the tach will drop to 0 immediately even though the engine is still turning, because the computer *thinks* the engine has stopped because the crank sensor isn't sending a signal. Does that make sense?)
    -BC
  16. #16 Re: engine stalls
    May 2008
    Winnipeg, MB
    I think the tach reads 0 at the same time the engine stops because I notice the power steering is gone and the tach is at 0 at the same time.
    I will know more by Monday after the mechanic I have looking at it tells me what sensor he found to be faulty.
  17. #17 Re: engine stalls
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    On my '97 GT, the tach would drop to 0 while driving (accompanied by a small shudder) for about 5 minutes before dying. When the tach died, thats when you knew to gtfo of the way of traffic and find a good spot to hang out. Then you'd have to wait about 10 minutes before it would restart after it died. Those were the symptoms of my bad cps.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  18. #18 Re: engine stalls
    May 2008
    Winnipeg, MB
    Talked with the mechanic this morning and they had found the MAF sensor was corroided and that is getting replaced.
  19. #19 Re: engine stalls
    St. Louis
    Hope they use a genuine GM MAF. These cars don't seem to fair well with aftermarket MAF's.
  20. #20 Re: engine stalls
    If you think it might be a crank sensor. Shotgun one on. I've seen a lot of funky behavior from a crank sensor.
    My first happy time with one was my car would seem to hiccup once or twice a day on the highway. I couldn't duplicate it, wasn't until I was scanning it and saw that the run time counter had restarted when the hiccup occurred. Literally my car had stalled and restarted. Tach didn't go to zero, none of the "expected" stuff mentioned above.
    I've also noted that on most crank sensors .. they are magnets and collect crap in between them.
  1. Car stalls when i put it in drive and rev up the engine
    By nopiddy in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-03-2012, 07:20 PM
  2. Engine bogs down/stalls when pumping brakes
    By Paranoid in forum Brakes/Suspension/Chassis
    Last Post: 07-21-2012, 02:52 PM
  3. Engine stalls while in Park, after coming down form a 2500-3k rev
    By fju2 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-01-2011, 07:55 PM
  4. engine stalls
    By robbie17 in forum Introductions/Noob Questions
    Last Post: 12-23-2010, 12:31 PM
  5. Engine stalls within seconds of starting
    By wadehosic in forum General Tech Discussion
    Last Post: 03-08-2010, 07:46 PM
