Thread: P0300 code , need help !!
Results 1 to 6 of 6
  1. #1 P0300 code , need help !!
    SE Level Member damohr's Avatar
    Mar 2015
    Canada
    so my car started running rough , i limped it home with a flashing CIL it sounded like its running on 4 cylinder instead od six just like an old tractor would , i found yesterday that the 1st and 4th cylinder wont get a spark so i went to Napa , got a new coil and replaced it thinking it fixed the issue .
    The problem is still there could it be a bad ICM ? or a sensor that controls the ICM , i"m confused since the other four cylinders are still working
    does anyone know what this could be ? any help would be highly appreciated
  2. #2 Re: P0300 code , need help !!
    icm probably.
    swap that new coil and put it where one of the other working coils. see if it still acts up on the coil pack in question.
    see if the icm needs to be cleaned where the coil sits.
    if none of this works find a used icm. new aint cheap.
  3. #3 Re: P0300 code , need help !!
    I would guess either the icm or maybe bad wires. Check the wires for cylinder 1 and 4 before digging into the icm.
  4. #4 Re: P0300 code , need help !!
    Mar 2015
    Canada
    ok ill try swapping the coil around tomorrow just to make sure napa didn't sell me a bad one , the contacts where the coil sits on are clean , i cleaned them before putting the new coil on, if that doesn't work ill go to the wrecking yard and pull an ICM , i was also thinking of getting the harness just to make sure its not a broken wire , thank you guys for the input really appreciate it
  5. #5 Re: P0300 code , need help !!
    Mar 2015
    Canada
    went to a junk yard and got a couple ICM's and a extra coil that looked brand new , cost me next to nothing , swapped the ICM cleaned the contacts and put it back together , it's running !!! So nice to hear the engine back in normal condition and not on 4 cylinders lol , thank you for all the information guys
  6. #6 Re: P0300 code , need help !!
    nice.
  1. someone help? p0300 code
    By ericg1181 in forum General Tech Discussion
    Last Post: 04-07-2014, 02:09 PM
  2. Stumped with P0300 code
    By zach101 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-20-2011, 04:56 PM
  3. 4-5k rpm misfire, Code P0300.
    By trailshredder in forum Engine
    Last Post: 11-13-2011, 07:43 PM
  4. most common p0300 code fix
    By Wingsfreak9 in forum General Tech Discussion
    Last Post: 09-21-2011, 01:12 PM
  5. Code P0303, and p0300
    By Progas in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2009, 09:08 AM
