Yes
OrThe only coolant up there is the loop running through the intake manifold and into the throttlebody. Throttlebody gasket failure or plenum gasket failure can both cause coolant pooling up that high.
If its pooling in the lower intake it can be what I mentioned before or a failed lower intake gasket. In rare cases it can be caused by someone not using thread sealant when doing a lower intake job.
