Thread: SD header install checklist
Results 1 to 14 of 14
gtpwannabe SD header install checklist 01-16-2015, 01:06 PM
REDCRAPGP Re: SD header install... 01-16-2015, 02:30 PM
gtpwannabe Re: SD header install... 01-16-2015, 02:39 PM
gtpwannabe Re: SD header install... 01-16-2015, 02:38 PM
Scottydoggs Re: SD header install... 01-16-2015, 02:41 PM
REDCRAPGP Re: SD header install... 01-16-2015, 02:42 PM
Scottydoggs Re: SD header install... 01-16-2015, 02:46 PM
REDCRAPGP SD header install checklist 01-16-2015, 03:02 PM
Scottydoggs Re: SD header install... 01-16-2015, 03:04 PM
gtpwannabe Re: SD header install... 01-16-2015, 03:49 PM
Scottydoggs Re: SD header install... 01-16-2015, 05:26 PM
gtpwannabe Re: SD header install... 01-16-2015, 04:16 PM
gtpwannabe Re: SD header install... 01-17-2015, 11:53 AM
Scottydoggs Re: SD header install... 01-17-2015, 11:58 AM
  1. #1 SD header install checklist
    Nov 2014
    South Carolina
    Hey everyone! I will be putting the SD headers on this weekend (97 GTP) and i just wanted to make sure i got everything..
    -2 3 inch band clamps
    -2 2 1/4 band clamps
    -Front and rear header gaskets (not the ones that came with them)
    -Already replaced the leaky flex
    Anything im missing? Thnx
  2. #2 Re: SD header install checklist
    O2 extension, rtv, and some beer. Oh and stick with oem gaskets!
    04 Comp G.
  3. #3 Re: SD header install checklist
    Nov 2014
    South Carolina
    Also do i need new o2 sensors? And any other gaskets other than the front and rear header gaskets?
  4. #4 Re: SD header install checklist
    Nov 2014
    South Carolina
    I forgot to mention i have the o2 extension from zzp. For the front sensor right? And which rtv should i get?
  5. #5 Re: SD header install checklist
    no gaskets are needed. no rtv either. get band clamps. the o2 can be reused. you'll need a o2 socket to remove it from the stock manifold.
  6. #6 Re: SD header install checklist
    You'll need one for the rear I believe, and copper rtv, reuse your O2 unless you need to replace them.
    04 Comp G.
  7. #7 Re: SD header install checklist
    rear what red? re use the stock head to header gasket. and thats it. if you need another use what they gave ya with the headers. no need to rtv anything if your slip joints are square and clamped.
  8. #8 SD header install checklist
    Don't use the crappy gaskets they give you with them.. Clean up the oem ones or replace them with oem ones from the dealer they're cheap.. And I'm referring to the post O2 sensors doesn't that need a extension to.. I know the prev gen is a bit different and the 97 are the bastard year so can't answer that one for sure. Copper rtv is cheap
    Insurance anyways.
    04 Comp G.
  9. #9 Re: SD header install checklist
    the post cat o2 in the U bend will likely not come out with out a torch. easier to buy a new one.
  10. #10 Re: SD header install checklist
    Nov 2014
    South Carolina
    Ok so what your saying is to clean up and re-use all the gaskets but i will most likely need the downstream o2 sensor? And maybe some copper rtv just in case?
  11. #11 Re: SD header install checklist
    Quote Originally Posted by gtpwannabe View Post
    theres only two gaskets you can reuse. they are on the head already. the extension is for the up stream o2. buy a new post cat o2 if the one in there wont come out. its a 7/8 th wrench. try to take it out before you drop the pipes.
  12. #12 Re: SD header install checklist
    Nov 2014
    South Carolina
    And the extension is for the rear o2? Sorry for all the questions i just wanted to have it all planned out.
  13. #13 Re: SD header install checklist
    Nov 2014
    South Carolina
    Cool thanks. Last question just making sure i got it right. The 2.25 band clamps are for the downpipe reducer and the 3 inch ones are for the crossover? Hopefully wont need any rtv..
  14. #14 Re: SD header install checklist
    dp is 3 inch. cross over is the 2.25.
  1. ZZP Header Install
    By Xorbex in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2010, 09:08 PM
  2. Header Install
    By GP_Kid18 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2009, 11:12 PM
  3. S&S Header Install
    By GRANDPRIXFOOL01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2009, 09:57 PM
  4. my header install needs help
    By gtphayes in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2009, 04:57 PM
  5. OBX Header Install is Done!!
    By Uno99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2009, 12:43 PM
