Thread: Coolant leak
Results 1 to 6 of 6
  1. #1 Coolant leak
    Jan 2013
    Kansas
    My 2008 GP recently developed a pretty major coolant leak, I notice its pretty wet around the water pump so anybody know if its the water pump or the hose? What would be the best way to get to the water pump since its in a bad position. Also I'm thinking about swapping over to the green coolant since I'm running the red stuff in there. Is it a good idea to switch over to it? What are your guys recommendations? Thanks in advance.
  2. #2 Re: Coolant leak
    Above or below the pump it's leaking?
    Could be the coolant elbow that blew, they are common.
  3. #3 Re: Coolant leak
    Sep 2012
    Cedar Rapids, Iowa
    Could be the coolant elbows that are right by the water pump. Otherwise I'd be sure to check the coolant hoses as well.
  4. #4 Re: Coolant leak
    GTX Level Member 2007GPGTSC's Avatar
    Nov 2013
    Des Moines, IA
    If the pump is bad its easy to get out. You will need to move the PS pump to get to the last WP bolt.
    Check elbows first.
    If its not that the bearings on the WP are probably failing causing the leak
    2007GPGTSC
    mods : HAI, PLOG, 3in DP , TG Shift Kit, AL 605's, POLY DB's
    Quote Originally Posted by 2007GPGTSC View Post
    " sad thing is "
  5. #5 Re: Coolant leak
    Jan 2013
    Kansas
    Thanks guys, I checked it out, hadn't looked at the elbows before I took the pump off and then noticed one elbow was broken off. So I'm assuming that's the only problem since the water pump looked fine, and it was dirty/wet above the pump so I should have figured to look there first, thanks guys!
  6. #6 Re: Coolant leak
    Sep 2012
    Cedar Rapids, Iowa
    Make sure to pull the little rubber rings out before you put the new one in so the new one sticks in there well!
  1. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  2. Coolant Leak
    By 99grandprixman in forum General Grand Prix Discussion
    Last Post: 01-06-2013, 06:43 PM
  3. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  4. Coolant leak
    By john breit in forum General Tech Discussion
    Last Post: 02-12-2011, 05:12 PM
  5. Help with coolant leak
    By eagleeyes9 in forum General Tech Discussion
    Last Post: 12-09-2008, 04:45 PM
