Thread: 15.3 volts?
Results 1 to 7 of 7
  1. #1 15.3 volts?
    Akron, Ohio
    Dammit. So thought I finally fixed everything. And just installed a transit blu hf. Car runs perfect. Took it for a test drive. All was good. Then started scanning the gauges cause I was bored at a stop light. Saw that it was charging at 15.1 to 15.5 volts. Do I care? Is it ok for the car to go down to Ohio State for a few weeks before I look into it?
  2. #2 Re: 15.3 volts?
    sure, as long as the battery's not taking a crap. lots of guys are at 15 volts.
    mine is like high 13 at idle to 14 when on the gas moving.
  3. #3 Re: 15.3 volts?
    The Boss Iceman6669's Avatar
    Jun 2011
    over 15.3 I have heard that certain things stop working though. Stuff like certain stereos and such.
    2011 F-150 Yote powered
  4. #4 Re: 15.3 volts?
    Aug 2013
    McDonald PA
    Quote Originally Posted by Iceman6669 View Post
    My stock voltage gauge after cleaning and reinstalling my connections just a few days ago was at 15.4. Everything was working fine
  5. #5 Re: 15.3 volts?
    Akron, Ohio
    Went to get another alternator while my son drive around. I asked him what the voltage was while he was driving. 14.2 to 14.7 with the headlights on. Didn't buy the alternator. Just going to watch until the temps get above 0
  6. #6 Re: 15.3 volts?
    Buffalo
    When it's cold out, first start driving, I see at high as 15.1 sometimes 15.2 or 3
    zzp st1 volt booster
    normally 14.8
  7. #7 Re: 15.3 volts?
    Oct 2011
    Toledo, OH
    My voltage on the 05 gtp has always been above 15 after cold starting. Highest I've ever seen it was 15.68 this winter when it was in the single digits. Factory battery lived for 9 years with me seeing that voltage daily for the first 2 years I've owned it.
    7"
  1. Battery Volts? LS4
    By bluelinev8 in forum 5.3L V8 (LS4)
    Last Post: 01-21-2014, 11:39 AM
  2. Getting 2.5 volts at fuel/sending unit....how come?
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-03-2011, 08:39 PM
  3. wiring up my VOLTS GAUGE =] 1 Q
    By GTPJOE90 in forum Audio, Security & Visual Electronics
    Last Post: 09-26-2009, 01:50 PM
  4. 13.25 volts and it wont start, just ticks. HELP PLEASE!!!!!!!!
    By RichCresci in forum General Tech Discussion
    Last Post: 11-15-2008, 08:34 PM
  5. low volts on throttle positioning sensor????
    By DONDON3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-26-2008, 03:28 PM
