Thread: I can add some 91 to E85 to bring my LTFT down. Confirmed.
Results 1 to 20 of 20
  1. #1 I can add some 91 to E85 to bring my LTFT down. Confirmed.
    Mar 2014
    Tucson
    I recently converted to E85 by swapping to 42lb injectors without a tune. Ran two full tanks through without a problem. Car loved the corn juice. Killed all my knock! LTFT settled in between 10-11. Life was good.
    Until...
    My last fill up. Shortly after topping up this last time, my LTFT began creeping up. To the point where I'm at 16.4 under acceleration and while cruising. Even set a MIL. (P0170 Bank 1 too lean.) I am almost certain it's fuel related because it happened right after my last fill up, and all my mechanical maintenance is up to snuff. New(ish) plugs, wires, fuel filter, and a walbro 255 pump. Rail pressure is about 45 while parked.
    So here's my question:
    Can I throw a couple gallons of 91 in the tank to try to bring my trims down? Would this hurt anything?
  2. #2 Re: Can I add some 91 to E85 to bring my LTFT down?
    Kemmerer, Wyoming
    I would still bet its a vacuum leak.
  3. #3 Re: Can I add some 91 to E85 to bring my LTFT down?
    Kemmerer, Wyoming
    take a look at this page: http://pontiacbonnevilleclub.com/for...p?f=19&t=14617
    it says if its high at idle then its probably a vacuum leak, but if its highest while driving then its probably a fuel delivery issue. did you do a pulley drop and/or a new fuel pump?
  4. #4 Re: Can I add some 91 to E85 to bring my LTFT down?
    Mar 2014
    Tucson
    My first thought was vac leak also, so I did the propane check. Didn't yield any results. The only thing that changed between my 10.9 LTFT and 16.4 LTFT was a tank of fuel.
    Definitely highest while driving. Maxed out at 16.4. Sitting at a light it comes back down to 10.9. I guess it's possibly a fuel delivery also. I have an AEM 340 LPH E85 pump on order. I though my Walbro 255 would have been enough. It just seems weird that it happened right after a new tank of fuel.
    I was just thinking, if I throw some 91 in it, that might bring my LTFT down. Would't that confirm or rule out a fuel quality issue?
  5. #5 Re: Can I add some 91 to E85 to bring my LTFT down?
    Kemmerer, Wyoming
    I have no idea if adding 91 would bring it down. I haven't ever run e85. the other thing that could cause a reading that high is an exhaust leak. when I put my speed daddy headers on I had a pretty good leak where the front manifold connects to the crossover. you can put your had near the junction and feel the air coming out if it is leaking. it could also leak at the rear junction, but mine only leaked from the front.
  6. #6 Re: Can I add some 91 to E85 to bring my LTFT down?
    Mar 2014
    Tucson
    I did have a small leak where the front header meets the crossover, but I sealed that up. Like I say, first two tank were great. Last fill up=poopy.
    I'm gonna try it. What's the worst that could happen?
  7. #7 Re: I can add some 91 to E85 to bring my LTFT down. Confirmed.
    Mar 2014
    Tucson
    It worked. 2-1/2 gallons on top of the half tank I already had, brought me back to where I was before my last fill up.
    Gonna try the E85 from a different place next time. See if there's a difference.
  8. #8 Re: I can add some 91 to E85 to bring my LTFT down. Confirmed.
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    http://www.grandprixforums.net/threa...ur-car-for-e85
    Read it. Learn from your mistake. Enjoy the corn.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  9. #9 Re: I can add some 91 to E85 to bring my LTFT down. Confirmed.
    Mar 2014
    Tucson
    Using method #1 what was my mistake? What did I do wrong?
    Great write-up BTW! I did read through it at least once. Although, there were some distractions in the background at the time.
  10. #10 Re: I can add some 91 to E85 to bring my LTFT down. Confirmed.
    Apr 2011
    South Dakota
    I will probably rephrase #1 later to make it more clear that its a really bad way to do it. For now ill single out these quotes from #1.
    This will never be 100% correct
    Its just too crude to get a steady air fuel ratio at wide open and your fuel trims will always be a bit off.
    I love Decker<3
  11. #11 Re: I can add some 91 to E85 to bring my LTFT down. Confirmed.
    Apr 2011
    South Dakota
    Finished tweaking it. I was a little drunk when I was writing that section. Im a happy drinker so I was WHHAAAYYYY too nice. Edited it to make it a little more angry.
    I love Decker<3
  12. #12 Re: I can add some 91 to E85 to bring my LTFT down. Confirmed.
    Mar 2014
    Tucson
    Quote Originally Posted by Frosty View Post
    That's fair. I do plan on doing my own tuning in the future. I just couldn't wait to get on the corn. Still no regrets. It killed the 3° of KR I was seeing even after CAI, headers and colder plugs.
    I guess I'll just have to be less surprised in the future if/when my trims go bonkers. Knowing that I can dial the LTFT down with 91 is reassuring.
    Thanks for chiming in!
  13. #13 Re: I can add some 91 to E85 to bring my LTFT down. Confirmed.
    LOL with more and more people switching to E85 my dreams of people finally realizing intercoolers are a waste of time and money may finally become reality!
    (don't waste you breath with the bawling you cant run E85 because there isn't any near you, if that's the case only one reasonable choice remains...... MOVE!!!)
  14. #14 Re: I can add some 91 to E85 to bring my LTFT down. Confirmed.
    Apr 2011
    South Dakota
    I still love my 2.55" and full stack you intercooler hater you.
    I love Decker<3
  15. #15 Re: I can add some 91 to E85 to bring my LTFT down. Confirmed.
    Mar 2014
    Tucson
    Not gonna lie, I may own an intercooler some day also. As far as "more and more people switching to E85" I think its great too. I really enjoy reading all the E85 threads. I like all the discussion and spread of solid information!
  16. #16 Re: I can add some 91 to E85 to bring my LTFT down. Confirmed.
    Bastard Reptile's Avatar
    Kansas City, MO
    Just curious here, did you change the fuel filter after running a couple of tanks?
    If it's plugged, it'll cause it to lean out. IIRC your rail idle should be in the low/mid 50's psi wise.
  17. #17 Re: I can add some 91 to E85 to bring my LTFT down. Confirmed.
    Mar 2014
    Tucson
    I did change the filter. I thought the same thing. No difference. Everything went whack after that last fill up. I thought rail pressure was supposed to be like 43 psi?
  18. #18 Re: I can add some 91 to E85 to bring my LTFT down. Confirmed.
    Kansas City, MO
    I'm just going off of memory here, so I could be wrong. Still, I don't think that it would cause THAT much of a fuel problem.
    Just switching injectors is a crude way of doing it, even though I've seen it brought up here lately more than I care to see. It's all opinion I suppose.
  19. #19 Re: I can add some 91 to E85 to bring my LTFT down. Confirmed.
    Mar 2014
    Tucson
    I hear you. I should mention, it's not my end game. I do plan to tune, eventually. It just really threw me off because my first two tanks went through as predicted. Trims and all. I was surprised to see that much of a difference between fill ups.
  20. #20 Re: I can add some 91 to E85 to bring my LTFT down. Confirmed.
    Mar 2014
    Tucson
    I didn't see any anger there. Some strong words of discouragement, sure.
    I get where all the "you have to tune it" guys are coming from. If this car was my daily, and only mode of transport, there's no way I would roll the dice on some of the stuff I do. But it's a hobby/grocery getter. I'm willing to play with things a bit. It's reminiscent of the old school hot rodders who would do different things just to see what would work, and work the best.
  1. bring back from the dead
    By 1998gt in forum General Grand Prix Discussion
    Last Post: 07-18-2014, 09:39 PM
  2. Chances of bring this down in price?
    By vicious in forum General Tech Discussion
    Last Post: 06-17-2011, 05:25 PM
  3. Bring's a tear to my eye
    By LowRidinCrew in forum Off Topic Discussion
    Last Post: 04-26-2011, 01:43 PM
  4. Time to bring her back ;)
    By KwazrollinZ28GTP in forum Off Topic Discussion
    Last Post: 11-29-2010, 10:25 PM
  5. Bring the flames
    By Sabrewings in forum Off Topic Discussion
    Last Post: 09-19-2009, 08:32 AM
