Thread: Who here has a belt wrap kit from wbodystoere?
Results 1 to 5 of 5
  1. #1 Who here has a belt wrap kit from wbodystoere?
    GT Level Member Hardonyomom's Avatar
    aurora
    I am thinking of getting the belt wrap kit instead of an 8 rib setup. Who has one of these and are they a pain to install? How do you install one? How effective are they??? Can someone post pictures of their setup if you have one. Thanks
    F body Front, GXP rear brakes, SSC, Poly Dogbones, SLP Gen 1 spoiler, Gpo's, GTX hood, SD Air dam, LED tails, badges and decals, Comp G Seats,
    FSIC, Ported and painted Gen 3, ZZP LIM, SD Headers, REmoddified ZZP fuel rail, 60 lb injectors, LS7 lifters, 1.9 modded rockers, 2.6 pulley E85, 21 degrees timing -Timboku tuned
  2. #2 Re: Who here has a belt wrap kit from wbodystoere?
    hangover park IL
    its easy as hell, might have to fiddle with your IC hoses if your running em past the icm instead of between the belt drives.
    3 bolts, easy, though the gen 5 torx bolts can be a pita...crack em free while its on the car and keep it straight with a good socket
    ~James~ Psychotic Gearhead
  3. #3 Re: Who here has a belt wrap kit from wbodystoere?
    Buffalo
    I'm looking to buy a gen5 belt wrap kit to match my 8 rib set up....
    Figured have the best of both worlds
    Anyone selling one let me know
  4. #4 Re: Who here has a belt wrap kit from wbodystoere?
    Buffalo
    Quote Originally Posted by Turbocharged400sbc View Post
    Why is the oil filter sideways ?
  5. #5 Re: Who here has a belt wrap kit from wbodystoere?
    hangover park IL
    F body oil neck
  1. Go 8 rib or get a belt wrap?
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2013, 10:49 AM
  2. More belt wrap with a SSM90
    By Frosty in forum How To Write-Ups/Tech Tips
    Last Post: 01-26-2013, 04:48 PM
  3. PC Belt Wrap Kit finally on the car....
    By Iron Indian in forum Off Topic Discussion
    Last Post: 10-20-2008, 10:11 PM
  4. SS M-90 belt wrap solution!!
    By chico in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-12-2008, 09:38 PM
