Thread: gas mileage is turrible. can anybody help with clues?
Results 21 to 40 of 42
  1. #21 Re: gas mileage is turrible. can anybody help with clues?
    Oct 2014
    Do you get any knock with that setup? Seems like most people have more exhaust mods to support a 3.4 pulley. Not trying to criticize, just curious. I know every motor reacts differently to mods. Sounds like new plugs was a good call.
  2. #22 Re: gas mileage is turrible. can anybody help with clues?
    GT Level Member Shiftingshaddow's Avatar
    KC
    0 knock retard. scanned a couple times to make sure. never given an issue yet. i did quite a bit of research before i took the chance on it. there were several people on here running 3.4 without headers or plog. there was also a grand prix website other than this that laid out the modding steps and on their 3.4 setup only the ubend delete was necessary. i wonder, with some people having trouble on the 3.4 setup if they have other issues with the car, like they aren't running the right plugs or something. that might be too simple but i ran it once with stock grade plugs and it was worse than the 3.8 and i thought it was going to screw up. the 104s were in some mod requirement lists i came across but i had never changed plugs before by myself so i hoped to not have to. but it turned out to be easier than i thought. i didn't think you could reach them from the top but you can.
    2001 GTP Special Edition
    ZZP DP with Cat, Open Cone Intake, ZZP 1.0 PCM, 3.4 pulley, AL 104s, Rocker Panel Delete.....
  3. #23 Re: gas mileage is turrible. can anybody help with clues?
    It had more to do with the tolerances that GM has, iirc zzp noticed that on some cars the head gaskets hung over into the combustion chamber and that little bit of gasket caused the car to have kr. Some cars flow better from the factory than others do as well again do to GMs tolerances.
    On my black car I had headers, ported blower, 104s, and open cone intake on a 3.5 and I still had kr.
    Sent from my Galaxy Far Far Away
  4. #24 Re: gas mileage is turrible. can anybody help with clues?
    Aug 2013
    McDonald PA
    To be honest Zzp tunes dump fuel so that could be an issue
  5. #25 Re: gas mileage is turrible. can anybody help with clues?
    Yup dump fuel to kill kr.
  6. #26 Re: gas mileage is turrible. can anybody help with clues?
    KC
    i drove the car for a couple months before i swapped pulleys and changed the pcm. fuel mileage dropped a bit as zzp said it would. but it has gone WAY down even from that point in the last month or so.
    i have history on the setup. it got better than 13 mpg even when i drove it hard prior to this issue. but as i posted above changing the plugs helped get back to the normal performance. in the next few days i hope to clean the MAF and i've come across some posters suggesting cleaning the throttle body so i'll pull that off and look at it as well.
    does anyone know off hand what size the torx head is for the MAF sensor? i gotta buy one for that.
    thanks for all your help everyone
  7. #27 Re: gas mileage is turrible. can anybody help with clues?
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Maf sensor just has 2 screws holding it in place, they are torx style bits.
    Not meaning to nitpick, but he'll need security torx, rather than regular torx bits, if he decides to do this. Failing that, he can always redneck it and cut some slots in the screws.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  8. #28 Re: gas mileage is turrible. can anybody help with clues?
    KC
    Quote Originally Posted by GTP131 View Post
    do you know what size?
  9. #29 Re: gas mileage is turrible. can anybody help with clues?
    KC
    Quote Originally Posted by Jeff Murray View Post
    Quote Originally Posted by Shiftingshaddow View Post
    My wife pulled up the computer and saw my reply to your post about knock retard and she says to me "Did you mean to call that guy a retard?" Funny. So she got a lil lesson.
  10. #30 Re: gas mileage is turrible. can anybody help with clues?
    people have literally been offended by the "knock retard" line before. one guys like i didnt come here to be called names lol
  11. #31 Re: gas mileage is turrible. can anybody help with clues?
    Yeah why you got to be calling people retards.
  12. #32 Re: gas mileage is turrible. can anybody help with clues?
    SE Level Member thekidinbuff's Avatar
    May 2013
    Buffalo, NY
    I do believe it is a T20 security bit
  13. #33 Re: gas mileage is turrible. can anybody help with clues?
    KC
    Quote Originally Posted by Slick2500 View Post
    It causes me a lot of problems. I just can't help it. But its more sensitive than calling people mongoloids.
    Quote Originally Posted by thekidinbuff View Post
    hey thanks. hopefully i can buy just the one at the parts store.
  14. #34 Re: gas mileage is turrible. can anybody help with clues?
    Mar 2012
    NC
    On a similar note my wife's GP was averaging pretty tuuuuurrrrrrrrrible fuel economy as well. Here were my findings:
    FPR leaking...big surprise. Gained 2.1 mpg
    O2 sensor was built by people with very little hands...aka cheap Chinese crap. Denso O2 gained me another 1.2 mpg
    KR through the roof...amazing on a L36...but it happened. Replaced front knock sensor and amazingly it went away Gained me yet another 1.7 mpg
    Spark plugs...previous owner "lets put some new cheapo Autolites in there"...WRONG. Put AC Delco iridiums back in and gained another 1.9 mpg
    So, we started averaging 24 mpg highway and it's currently up to 31.9 mpg. Amazing what dumb little things will do.
  15. #35 Re: gas mileage is turrible. can anybody help with clues?
    May 2013
    Buffalo, NY
    I went to Advanced and for some reason they sold the non security bit ones separately but not the security bits. You have to buy them as a set.. at least at my store you have to. I ended up using pliers to unscrew mine lol
  16. #36 Re: gas mileage is turrible. can anybody help with clues?
    Enfield, CT
    Burn the ZZP PCM...
  17. #37 Re: gas mileage is turrible. can anybody help with clues?
    KC
    Man, dats turrrriiible.
    i have thought about replacing 02 sensor as well. There are some things i'm learning along the way. You see, I thought when the car starts running like crap, getting really awful gas mileage, there would be some engine code to indicate that something is wrong and one might get some clues. this is proving to not be the case, however, and it can be sort of a witch hunt.
    i didn't find any at all at advance. i was thinking of hitting an oreilly. walmart didn't have any sets even. ace might. but if it comes off with a pliers i'll just try that.
    Quote Originally Posted by HighOctaneRacing View Post
    Burn the ZZP PCM...
    i still have the stock one. but i have no way to tune it, i don't know anyone that can tune it, and i think i shouldn't spend money tuning a basic setup like that. if i dragged it ever, i would want to go deeper on mods to where it would require a custom tune.
    now, if i had a way to tune it myself and i could learn a lot doing so it would be worth it to me to try.
  18. #38 Re: gas mileage is turrible. can anybody help with clues?
    your in KS, go see reptile. hes your local tuner.
  19. #39 Re: gas mileage is turrible. can anybody help with clues?
    KC
    how much monopoly money will he take?
  20. #40 Re: gas mileage is turrible. can anybody help with clues?
    hes still selling caned tunes, you'll have to pm for his in car tunes price.
    this guy. http://www.grandprixforums.net/threa...s-98-02-GT-GTP
  1. any clues on this new sound? video inside
    By FullOutPwr in forum General Tech Discussion
    Last Post: 11-03-2014, 06:52 AM
  2. Better Gas Mileage?
    By Adidasdude1989 in forum General Tech Discussion
    Last Post: 08-04-2012, 06:37 PM
  3. gas mileage ???
    By v8teezr in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2011, 07:13 PM
  4. bad gas mileage
    By Joe m in forum General Tech Discussion
    Last Post: 02-03-2010, 02:17 PM
  5. Better mileage on an old V8 than a GTP LoL!
    By Juanmiguel in forum The Rant Forum
    Last Post: 01-28-2010, 09:26 PM
