FordMan77
Typically yes it would be the resistor, but because of the OP's statement right here " Also, when the fan is turned on for speeds 1-4, the automatic headlights don't work, the headlights will only function in manual mode or if the fan is turned off, or on speed 5. I have replaced the resistor with a new updated one and I still have the same problem. I replaced the HVAC control switch and still the problem is there only works on speed 5."
He already replaced the blower resistor and HVAC switch. Plus the headlight issue as well. The blower resistor going bad does not have a direct effect on the autolamps usually, but everything being tied to the ignition switch would.
