Thread: Wideband sensor failing or problem?
Results 1 to 7 of 7
  1. #1 Wideband sensor failing or problem?
    Buffalo
    Car wash, got gas and Wideband starts acting up.
    Dont know fuel trims as both aerroforces refused to boot recently - fml
    so it usually flicks between 14.x and 15.x unless I rapidly deaccel it will go to LEN or AIR and quick jabs brings it into the 13s
    well after I left I noticed I was getting into the 16s and 17s
    slowly de accelerating was causing instant LEN where that usually only happened over 60mph
    a good WOT run still showed 11s and 12s but it's definitely not right.
    I was thinking maybe a gasket leak but it doesn't sound loud.
    Maybe the sensor finally failed?
    Anyone experience anything similar ?
  2. #2 Re: Wideband sensor failing or problem?
    Mar 2014
    Tucson
    I don't have a wideband yet, but very recently my LTFT's were bouncing at or near 16.4 and I got a P0170 (Bank 1 too lean). This started almost immediately after my last fill up. I'm running E85 on a stock tune with 42# injectors. First two tanks went through fine. LTFT's consistently around 10. Then all the sudden, boom. I'm lean.
    Did they recently switch to winter blend? Shouldn't that have happened a while ago? Could that cause what we're seeing?
  3. #3 Re: Wideband sensor failing or problem?
    Buffalo
    ^ very strange possibility. I never drove this car in the winter before with a Wideband. Been parked every year .....
  4. #4 Re: Wideband sensor failing or problem?
    How many miles on the sensor??
    I'd replace it if it was more than 15-20k on it, even though they say it can last 40-50k.
    I'd double check the power wiring to the gauge too.
  5. #5 Re: Wideband sensor failing or problem?
    Nov 2011
    NY
    The sensors wear out just like your regular O2. As FFDP mentions. . .
  6. #6 Re: Wideband sensor failing or problem?
    Buffalo
    Damn... Just like that huh
    Guess it can't hurt to grab a new one and try it out
  7. #7 Re: Wideband sensor failing or problem?
    Buffalo
    Update
    car on lift and everything is solid, clean and sealed. No rust no broken wires no leaks.
    Truth is , i don't think the wideband lied. It actually told me something about the gas being sold from a popular car wash chain, delta sonic
    I ran that tank to empty and re filled twice at the same Sunoco. The gauge is reading like it was before this issue - completely normal.
    NEVER have I seen this before and I have had gas from all over here to ohio - no issues ( BP, mobile, crosbys...)
    Seem like they might be using a bit more than E10 in those 93 pumps...
  1. brake apply sensor failing?
    By Jesterville in forum 5.3L V8 (LS4)
    Last Post: 04-11-2015, 08:04 AM
  2. Wideband o2 sensor install questions
    By Beatdowncity in forum Introductions/Noob Questions
    Last Post: 12-01-2014, 08:45 PM
  3. Best place to put wideband sensor
    By timboku in forum General Grand Prix Discussion
    Last Post: 03-14-2014, 07:18 AM
  4. 1994 Grand Prix SE - unusual problem caused by failing motor mounts
    By Rebii1 in forum Introductions/Noob Questions
    Last Post: 04-17-2013, 10:02 PM
