Thread: Trunk Latch wont work? Need some help
Results 1 to 8 of 8
  1. #1 Trunk Latch wont work? Need some help
    Jul 2010
    Canada
    I opened my trunk one day and it wouldnt close, I got a part from the wreckers that supposedly worked. Put it in and it wouldnt work hmmmm. I bought a brand new trunk latch and it still doesnt work. When plugged in and I hit the button on my fab it unlocks. What could be the issue???? Very confused
  2. #2 Re: Trunk Latch wont work? Need some help
    Take a look in your owners manual. I know on the older models you couldn't have the car in gear. Maybe there's more to it in 08
  3. #3 Re: Trunk Latch wont work? Need some help
    Dec 2014
    nebraska
    My 2008 Grand Prix trunk latch just stopped latching today. It seems like everything works properly and is secure, so I can't figure out why it wont lock. If I stick a screwdriver through the latch (mimicking the loop on the car), the latch itself locks and unlocks properly. The latch does not seem loose or out of place, nor does the loop, and the trunk door goes down as far as it can. The hinges seem secure too. I just can't figure out why it wont latch when the door is closed. Did anybody figure anything out?
  4. #4 Re: Trunk Latch wont work? Need some help
    Try adjusting the bump stops so the lid can sut further. Half turns at a time.
  5. #5 Re: Trunk Latch wont work? Need some help
    Dec 2014
    nebraska
    Ok guys, I fixed it. I loosened the outer nut on the loop bracket and pulled up on the loop as much as it could go, which wasn't very much, and then tightened the nut. That was just enough to make it work. Then I backed out the two bumper stops until it wouldn't latch, and then screwed them in a little further until it worked again. Since they were all the way in when I started, the latch may have bottomed out on the loop, forcing the loop down too far. Hopefully with the bumper stops out further, they will prevent this from happening again.
    Scottydoggs, thanks for your suggestion. It was on the right track.
  6. #6 Re: Trunk Latch wont work? Need some help
    Dec 2014
    nebraska
    The stops are already in as far as they can go. I even removed the bottom panel because I thought maybe it was popped up on one side, but it still doesn't work. The last thing I can think of is loosening the loop bracket and pulling it up further, then tightening it down. I'm at work, so I'm trying to find some metric wrenches. It's on tight though, so I can't imagine that it got pushed down at all.
  7. #7 Re: Trunk Latch wont work? Need some help
    1/2 on track, i didnt know the loop could move.
    i bet what happened was the latch lock may have been closed, then shut, and it pushed that loop down. or just time maybe. who knows, but good find.
  8. #8 Re: Trunk Latch wont work? Need some help
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    same thing happened on my 97. Had to take the latch off and slot it so It would move down further and latch itself.
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  1. door wont shut? latch stuck
    By nickgpgt in forum General Grand Prix Discussion
    Last Post: 12-26-2013, 09:41 AM
  2. Trunk Latch
    By 97whitelightning in forum General Tech Discussion
    Last Post: 09-28-2013, 02:33 PM
  3. Cargo Net Stuck in Trunk Latch
    By Dabman in forum General Tech Discussion
    Last Post: 04-21-2012, 11:55 PM
