If you're temps are reading ~160, your thermostat isn't doing it's job (or the temp sensor is bad). Replace the thermostat. I'm not sure where TDCRacing is coming from on this, but this is absolute basic auto mechanics. The thermostat is there to regulate coolant flow through the radiator and keep the engine at a pre-determined temperature. Too much flow = too cold.
Thank god someone with some sense has finally come to this thread. When it is 30 degrees outside in pennsylvania and you have an open t-stat, your engine is not going to warm up. This guy does not live in georgia.
