If you're thermostat was bad or not working right you would likley be experiencing overheating issues with you're car.
Quote Originally Posted by rfmgtp02 View Post
Not if it is stuck open
The statement about how a cooling system and fans on a car works is becuase of the above statement that you made.
If that were the case I would have just took my thermostat out to acheve lower temps instead of buying a 160.
These fans on our cars do pull a lot of air and while I guess it is POSSIBLE that if the fans COULD keep up it may be able to keep it from overheating theres 2 things that would NOT happen.
It would not be a steady tempeture.
It would not be anywhere near 160*
The stock PCM fan on/off settings are-
Fan 1
212*F on
207*F off
Fan 2
226*F on
223*F off
The problem is more than likley in the climate control system. Such as one of the blending doors being stuck on the upper vent setting only.
