Thread: P0171 16.4 ltft 20 stft
Results 1 to 20 of 30
Threaded View
  1. #1 P0171 16.4 ltft 20 stft
    I swapped in some 42.5# injectors and switched to E85 and immediately the LTFT was pegged at 16.4
    When I first start the car the STFT sits between 0-5% then the idle drops down to normal and the STFT slowly creeps up and sits at 20%, the LTFT is constantly at 16.4.
    So far I have replaced all the vac lines and Ts with new lines and I replaced the o rings on the injectors. If my car didn't have a full tank of E85 I would just swap back to my old injectors and see if the issue goes away
  1. P0171 Code LTFT Maxed @ Idle
    By dbextreme in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-28-2019, 01:38 AM
  2. Ltft show rich but wideband and stft say otherwise
    By tweeder in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-06-2014, 10:28 AM
  3. P0171 Code LTFT Maxed @ Idle
    By dbextreme in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-08-2013, 10:36 PM
  4. Help with LTFT
    By JerzNick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-03-2013, 12:05 AM
  5. Why LTFT, when STFT should be quicker
    By IndeedSS in forum PCM Tuning
    Last Post: 08-26-2008, 08:27 AM
