Thread: P0171 16.4 ltft 20 stft
Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
  1. #21 Re: P0171 16.4 ltft 20 stft
    Mar 2014
    Tucson
    Zero. It had maybe six tanks of 91 through it before the conversation, and I have yet to run a full tank of E85 through it. Not sure if its relevant, but there was very little crud in the tank visible when I changed the pump.
  2. #22 Re: P0171 16.4 ltft 20 stft
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    That's cool. You might not need to change it since you just did it before the switch. Thanks for all the info dude. And to everyone else too.
    And gl OP getting your trims worked out. Hopefully it either self corrects after a tank or two or you get a tune quick.
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  3. #23 Re: P0171 16.4 ltft 20 stft
    Its not going to self correct it would have done it by now as I have filled the car up twice and put on about 400 miles since then.
  4. #24 Re: P0171 16.4 ltft 20 stft
    Cleaned the maf, which was extremely Dirty, no difference. Sprayed around with carb cleaner no vac leaks. Seafoamed my engine and had exhaust coming out of the front clamp on my crossover so turns out that I have an exhaust leak......
    So looks like I'm going to need to pick up some ultra copper rtv.
    Sent from my Galaxy Far Far Away
  5. #25 Re: P0171 16.4 ltft 20 stft
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    copper rtv won't do anything on your crossover.. get a better clamp
    04 GTP -HAI, 1.9 rockers.
  6. #26 Re: P0171 16.4 ltft 20 stft
    I have a stepped band clamp on there I don't think there is anything better than that.
    http://shop.zzperformance.com/store/...st-Clamps.aspx
  7. #27 Re: P0171 16.4 ltft 20 stft
    i got the same kind on my headers.
    this one is a flat bland clamp. the rest of them are the stepped kind. no leaks at all. no copper rtv either, anywhere.
    maybe you need to loosen the front header and cross over clamps and wiggle it around some so they seal better?
  8. #28 Re: P0171 16.4 ltft 20 stft
    Its kind of odd that after 3 years it just up and started leaking.
  9. #29 Re: P0171 16.4 ltft 20 stft
    that is odd. maybe the clamp came loose?
  10. #30 Re: P0171 16.4 ltft 20 stft
    Idk I torqued it down real good but it didnt make any difference in my fuel trims.
  1. P0171 Code LTFT Maxed @ Idle
    By dbextreme in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-28-2019, 01:38 AM
  2. Ltft show rich but wideband and stft say otherwise
    By tweeder in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-06-2014, 10:28 AM
  3. P0171 Code LTFT Maxed @ Idle
    By dbextreme in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-08-2013, 10:36 PM
  4. Help with LTFT
    By JerzNick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-03-2013, 12:05 AM
  5. Why LTFT, when STFT should be quicker
    By IndeedSS in forum PCM Tuning
    Last Post: 08-26-2008, 08:27 AM
