Thread: Power steering fluid disappeared.
Results 1 to 16 of 16
  1. #1 Power steering fluid disappeared.
    Jun 2010
    long island ny
    95 GTP. I was driving today and the power steering was whining louder than usual, when I checked it it was almost empty. It was full the other day. No signs of leaks. I added more fluid and took it for a ride and went lock to lock with the steering and no leaks.
  2. #2 Re: Power steering fluid disappeared.
    it leaked out from somewhere. park over cardboard. could be the rack boots leaking or the pump, or the rubber line split. hard to say. look for a wet spot.
  3. #3 Re: Power steering fluid disappeared.
    May 2012
    Where winter never ends
    I pulled my engine and the pressure supply line got loose and I didn't notice... All of the fluid to the ground in less than 2 seconds :P That made some terrible, terrible sounds
    2000 Regal - Winter Beater
  4. #4 Re: Power steering fluid disappeared.
    Jun 2010
    long island ny
    High pressure line is new. After I got it home I checked under the car and nothing was dripping. Added fluid and went lock to lock and no leak on the ground. This isn't a few drips here and there this is the contents of the reservoir.
  5. #5 Re: Power steering fluid disappeared.
    Feb 2009
    flintnasty MI
    could have all drained into the rack... common problem.... need a new rack at that point.
  6. #6 Re: Power steering fluid disappeared.
    Jun 2010
    long island ny
    What do you mean it drained into the rack. and it needs replacement.
  7. #7 Re: Power steering fluid disappeared.
    idk what he mean either. p/s fluid dont just disappear. it has to leak out to be missing.
  8. #8 Re: Power steering fluid disappeared.
    Mar 2014
    Tucson
    Maybe he meant it could have leaked into the boot(s)? That can happen, right?
  9. #9 Re: Power steering fluid disappeared.
    the boots wont hold a res or two or three's worth of fluid. most of the time if the boots are wet theres your leak. blown seals, time for a new rack.
  10. #10 Re: Power steering fluid disappeared.
    Jun 2010
    long island ny
    It looks like it is coming from the rack. Right by where the hose go into it. How hard is this job to change the rack.
  11. #11 Re: Power steering fluid disappeared.
    its a blast, ive done mine 2 times so far lol
  12. #12 Re: Power steering fluid disappeared.
    Jun 2010
    long island ny
    I have done them on Citations and Cavaliers when I was a GM mechanic. Can't be much different. I had a little problem, as I was letting the car down the jack slipped and punched a small hole in the oil pan. Bad day today.
  13. #13 Re: Power steering fluid disappeared.
    how does the jack get near the oil pan?
    it cant be all that different a job. just tight places to work in.
  14. #14 Re: Power steering fluid disappeared.
    If you are on the subframe and the jack slips.. you could get a pan.
  15. #15 Re: Power steering fluid disappeared.
    Jun 2010
    long island ny
    Thats what happened. Small hole. Don't know what I am going to do to fix it yet.
  16. #16 Re: Power steering fluid disappeared.
    Dec 2012
    Where 4T65E's were born
    Don't even try the jb weld 2 part metal fix stuff. (The kind in a tube that you cut and mix with your hands, like a clay)
    At work one of my bosses fixup cars had an aluminum pan that had a crack from an accident. Not a huge crack, just like 2.5 inches long. We sandblasted the whole length of the crack on both sides, cleaned well, and used the jb weld on both sides. Let it fully cure before reinstalling, but still leaked like a sieve.
    If its steel, you can weld a patch if you're skilled enough. Or go to a junkyard and get one, or find the best deal on a new one.
    Sold.
  1. Power steering fluid in tie rod boots
    By indygrandprix in forum Brakes/Suspension/Chassis
    Last Post: 08-18-2013, 08:55 AM
  2. power steering fluid
    By tstaller2005 in forum General Tech Discussion
    Last Post: 05-03-2011, 10:34 AM
  3. Power Steering Fluid
    By Vlad0691 in forum General Tech Discussion
    Last Post: 11-12-2010, 08:48 PM
  4. Power Steering Fluid
    By FriboRage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-22-2010, 01:26 AM
  5. What power steering fluid is best?
    By dl1027 in forum General Tech Discussion
    Last Post: 05-09-2010, 07:55 PM
