Thread: Heat Takes Forever
Results 1 to 20 of 21
  1. #1 Heat Takes Forever
    May 2012
    Canada , Sarnia
    I have an 04 grand prix and its snowing where I live now and when I turn my heat on it takes forever and is not hot at all just started doing this I was thinking could need a new thermostat ???
  2. #2 Re: Heat Takes Forever
    Back flush the heater core and you'll have heat again.
  3. #3 Re: Heat Takes Forever
    I stand by my first post.
    Water behind the dash sound, makes my post even more clear.
  4. #4 Re: Heat Takes Forever
    Feb 2013
    37.295091, -121.930053
    Try new t stat and a flush if that dont work new heater core
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  5. #5 Re: Heat Takes Forever
    hangover park IL
    ive seen a couple aftermarket "fail safe" T stats stick open on cars. replace it
    i also have half my radiator covered in cardboard with a hole in the middle (for mechanics wire to remove in spring)
    ~James~ Psychotic Gearhead
  6. #6 Re: Heat Takes Forever
    GTP Level Member
    Aug 2012
    st louis park, MN
    First you could try opening the brass bleeder screw on top of the thermostat housing (once the car is to normal operating temperature) until a steady stream of fluid is coming out. I once had a slight leak in my coolant system that caused air to enter the system and the heat to blow only lukewarm air. One indicator of air in the coolant system is sloshing or watery sounds from behind the dash.
    If that doesn't work you can proceed with thermostat and coolant/heater core flush. Instructionals on both of those can be found on this site. Good Luck!
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  7. #7 Re: Heat Takes Forever
    you can always touch both heater core hoses, if both are hot, you should have heat. if one is warm, the other cold, the core is air bound.
    back to step one, flush the core.
    you cant bleed air from the core via the t stat bleeder. it just dont work like that.
  8. #8 Re: Heat Takes Forever
    May 2012
    Canada , Sarnia
    ok just put new thermostat in still no heat going to try what socker said sometimes in the morning that what it sounds like is water behind the dash
  9. #9 Re: Heat Takes Forever
    May 2012
    Canada , Sarnia
    ok just put new thermostat in still no heat going to try what socker said sometimes in the morning thats what it sounds like is water behind the dash when I start the car up
  10. #10 Re: Heat Takes Forever
    break out the garden hose, take both heater hoses off the alt bracket, then turn the hose on, and put it end to end with one of the heater hoses, flush till clear water comes out the other hose. put the hoses back on and enjoy the heat.
  11. #11 Re: Heat Takes Forever
    ^^^^^^^^^^^^this is how to flush your heater core.^^^^^^^^
    that other post is to flush the rad and engine for new coolant, or a coolant change of color.
  12. #12 Re: Heat Takes Forever
    Nov 2010
    Ray MI
    I had this problem. Replaced the T stat the heat works.
    1991 Grand prix GT
    1994 Cutlass Supreme
    2000 Grand prix GTP
  13. #13 Re: Heat Takes Forever
    May 2012
    Canada , Sarnia
    I forgot to add that the upper radiator hose had a hole in it last week could air have gotten into the system
  14. #14 Re: Heat Takes Forever
    Mar 2012
    NC
    Yes.
  15. #15 Re: Heat Takes Forever
    May 2012
    Canada , Sarnia
    Wish I could work on my car right now but at work
  16. #16 Re: Heat Takes Forever
    May 2012
    Canada , Sarnia
    Seen Scottydoggs post this in another thread this is how you backflush??
    remove the t stat, put the t stat housing back on, take the upper hose off the radiator, then push it down to the ground to a bucket or let it fly.
    get your garden hose out, put it in the rad turn it on, then fire up the car, let it run till clear water pumps out the top hose.*
    then turn the hose off, run the car till no more water comes out the upper hose. then turn it off.
    put your t stat back in, with new gasket, the upper hose back on.*
    now take 1 gallon of full strength green antifreeze, not the 50/50 crap. ( parts store cheap green is fine to use) dump the whole gallon in the radiator, fire up the car, fill the rad with hose water till its full. top as needed till its ready to be bled of air. it will burp and take coolant as the water in the block warms up the t stat opens up for a few seconds till cold coolant hits it and it shuts again.
    now to bleed the air out, let it idle rad cap off till the fans turn on, (when the fans are on the temp is over 195 deg, the t stat is wide open) then open the bleeder screw on top the t stat housing a few turns till a steady stream of coolant comes out the hole, shut the screw, top off the rad. cap it.
  17. #17 Re: Heat Takes Forever
    May 2012
    Canada , Sarnia
    all good just went to the place I go for my oil changes got a rad flush the heat is back on now
  18. #18 Re: Heat Takes Forever
    May 2012
    Canada , Sarnia
    just my luck tonight the heater hoses where the little elbow is starting leaking just make it home now my question is how hard are they to replace ?
  19. #19 Re: Heat Takes Forever
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    go buy aluminum ones in the help section.
  20. #20 Re: Heat Takes Forever
    May 2011
    Illinois
    check your pm, gordster
  1. Why does it take forever for my gt to heat up
    By raverockstar in forum General Grand Prix Discussion
    Last Post: 02-25-2013, 04:59 AM
  2. Car takes forever to warm up
    By Chadgervais in forum General Grand Prix Discussion
    Last Post: 01-29-2013, 08:02 PM
  3. Pontiacs forever!
    By Frostman in forum Introductions/Noob Questions
    Last Post: 09-08-2011, 09:22 PM
  4. Feels like FOREVER!
    By GTPontiacMan in forum Introductions/Noob Questions
    Last Post: 09-05-2011, 07:55 PM
  5. Done with the 3.8 FOREVER
    By KwazrollinZ28GTP in forum The Rant Forum
    Last Post: 05-13-2011, 01:53 AM
