Thread: Exhaust Manifold Firewall side?
Results 1 to 11 of 11
  1. #1 Exhaust Manifold Firewall side?
    Sep 2014
    United States
    This feels like a silly question but I am going to ask anyway. Because after searching this forum and google I could not find anything related to my situation. Maybe it is me and bad luck. I removed the engine from my 1999 GP GT to replace most of the gaskets. While doing this I broke the Exhaust Manifold bolts off in the flange that connects the cross over pipe to the fire wall side exhaust. Is there a special way to remove those bolts? The reason I ask is because when they broke I thought no big deal there is still part of the bolt left on the bottom end of the flange I will just use a pair of vice grips and work it out. Well that did not work I just ended up destroying the threads and the bolt never moves. I soaked them in Mr. Wrench and then tried again. Needless to say nothing. I can't get them out. So I bought some reverse drill bits and drilled it. I screwed that up by not drilling straight. So my last resort was to go to the junk yard and remove the exhaust manifold off of a car. Guess what happens? After getting all the bolts out of the manifold except the last 2 bolts that connects the cross pipe. The bolts breaks off in the flange again.
  2. #2 Re: Exhaust Manifold Firewall side?
    You need heat, lots of heat.
    Grab a MAP torch and get those things hot as nuts and then turn the studs.
  3. #3 Re: Exhaust Manifold Firewall side?
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    a little bit heat goes a long way man. find a fabricating shop and hand the guy $5 to get them out for you.
  4. #4 Re: Exhaust Manifold Firewall side?
    SE Level Member jimzssei's Avatar
    Sep 2014
    Having worked in an exhaust shop, back in the day, there is no easy solution to your dilema, but there are solutions.
    Heat is always a huge help... acetylene would work best, but even map gas will work.
    At this point I'd drill out what you can, heat each flange, not what's left of the bolt, and try an easy out.
    Sent from my SGH-S959G using Tapatalk 2
  5. #5 Re: Exhaust Manifold Firewall side?
    GT Level Member andesmint's Avatar
    Jun 2012
    Minot, Nd
    hmm... I may have a spare one laying around... I'll send it to you for the price of shipping i can find it. let me know if you want me to look
  6. #6 Re: Exhaust Manifold Firewall side?
    id drill that out and put a nut and bolt in there so fast, there wouldn't be a post till after it was done lol
  7. #7 Re: Exhaust Manifold Firewall side?
    Sep 2014
    United States
    Quote Originally Posted by andesmint View Post
    Thanks! I think I will swing by an exhaust shop and see if they can get them out. If not I may take you up on your offer. But I am going to try a few more things.... Glade to know I am not the only one who has had problems with these suckers. I have slowly been putting the engine back together and this has been a pain in my side.
  8. #8 Re: Exhaust Manifold Firewall side?
    Sep 2014
    United States
    I tried a reverse drill bit on one side but drilled it off center. Does any one have any suggestions on what bolts to use once I finally get these out.
  9. #9 Re: Exhaust Manifold Firewall side?
    May 2011
    Illinois
    grade 5 or grade 8 with some anti seize on the threads.
  10. #10 Re: Exhaust Manifold Firewall side?
    You can whack them hard enough for the nuts to break free. Been there..done that.
  11. #11 Re: Exhaust Manifold Firewall side?
    Sep 2014
    United States
    Quote Originally Posted by jamesivey24 View Post
    Thank you sir. I would be at a lost without this forum. So much information and knowledge and people do not mind sharing. I hope to be able to contribute one day.
  1. Passenger side speaker amp install 2004GP. How should I go through the firewall?
    By GPfoSHEEZY in forum Audio, Security & Visual Electronics
    Last Post: 07-13-2014, 08:39 PM
  2. Knock Sensor firewall side
    By jucaan in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-04-2014, 07:51 PM
  3. Y pipe to rear exhaust leak between engine and firewall on 2000 GTP
    By torqueaddict in forum General Tech Discussion
    Last Post: 12-30-2013, 04:54 PM
  4. Replies: 11
    Last Post: 08-01-2013, 04:22 PM
  5. 3.1 water coming from exhaust leak on exhaust manifold
    By ibhuff in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-21-2011, 01:54 PM
