Thread: Passenger side speaker amp install 2004GP. How should I go through the firewall?
Results 1 to 7 of 7
GPfoSHEEZY Passenger side speaker amp... 07-12-2014, 10:42 AM
Scottydoggs Re: Passenger side speaker... 07-12-2014, 10:46 AM
Russosaur Re: Passenger side speaker... 07-12-2014, 11:51 AM
GPfoSHEEZY Re: Passenger side speaker... 07-13-2014, 06:54 AM
GPfoSHEEZY Re: Passenger side speaker... 07-13-2014, 06:56 AM
ADrugDealer Re: Passenger side speaker... 07-13-2014, 07:26 AM
GPfoSHEEZY Re: Passenger side speaker... 07-13-2014, 08:39 PM
  1. #1 Passenger side speaker amp install 2004GP. How should I go through the firewall?
    Apr 2014
    Ontario
    I have an amp and sub in the trunk that is going through the door jamb(I know shame on me) and I am about to install another amp under the glove box, but I want to do it right and run wires through the firewall. If anybody could provide a diagram or picture or description of the best place to go through the firewall I would greatly appreciate it.
  2. #2 Re: Passenger side speaker amp install 2004GP. How should I go through the firewall?
    i took the pass side cowl off and drilled a hole under the windshield. then fed the wire in the hole and it just came out the bottom all easy like.
    others will use the rubber block in the pass side floor, or a fire wall grommet.
  3. #3 Re: Passenger side speaker amp install 2004GP. How should I go through the firewall?
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Im using the rubber block in the passanger footwell scotty mentioned. Works fine,
    You can kinda see where it goes, follows a big loom of wire through it.
    2012 F150 STX
    - Gonna be a race truck
  4. #4 Re: Passenger side speaker amp install 2004GP. How should I go through the firewall?
    Apr 2014
    Ontario
    Thanks guys. I ended up going through the grommet. I didnt even notice the rubber block or else I would have gone through there. My pass side cowl leaks too so I will have to fix that so my equipment doesnt get messed up.
  5. #5 Re: Passenger side speaker amp install 2004GP. How should I go through the firewall?
    Apr 2014
    Ontario
    For. The tweeters.in the front doors do you think they can be swapped with other tweets easily?
  6. #6 Re: Passenger side speaker amp install 2004GP. How should I go through the firewall?
    May 2012
    Where winter never ends
    Theres a thread on that fix. Has the part number you need to fix it. 10 bucks and 30 minutes later your done
    2000 Regal - Winter Beater
  7. #7 Re: Passenger side speaker amp install 2004GP. How should I go through the firewall?
    Apr 2014
    Ontario
    If its not too much trouble cpuld you link it? Im gonna search in the meantime.
  1. Knock Sensor firewall side
    By jucaan in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-04-2014, 07:51 PM
  2. Replies: 0
    Last Post: 07-12-2013, 10:22 AM
  3. ONLY one REAR passenger side speaker works now! PLEASE HELP!
    By thomasd2010 in forum General Grand Prix Discussion
    Last Post: 03-30-2013, 06:42 PM
  4. ONLY one REAR passenger side speaker works now! PLEASE HELP!!!!
    By thomasd2010 in forum Audio, Security & Visual Electronics
    Last Post: 03-23-2013, 10:03 AM
  5. A/C cold on passenger side and luke warm on drivers side
    By IFrees in forum General Tech Discussion
    Last Post: 05-14-2011, 05:06 PM
