Thread: Power window question
Results 1 to 8 of 8
  1. #1 Power window question
    GT Level Member gpbastard's Avatar
    Florida
    I have an 01 GP SE 4door. Yesterday I installed a new window regulator in the right rear door. It works fine but both the door switch and the master switch that controls that window now work in reverse. Up is down and down is up. Both the electrical connections that you hook up to only go on one way so I know it's not that. Any clues?
    gpbastard
  2. #2 Re: Power window question
    switch the power lines at the regulator power plug.
  3. #3 Re: Power window question
    Florida
    Thanks Scotty. The plug goes in only one way. Should I cut the two lines and then solder them back together? Does it matter if the window is up or down?
    gpbastard
  4. #4 Re: Power window question
    if the window switch is running backwards the power lines are backwards to the regulator.
    cutting and soldering maybe the only way.
    you know what....look at the plug end on the regulator, see if you can pull the wires out, ( most of the time theres a clip inside the plug to release them) and swap the pins around in the plug. someone may have goofed at the factory.
  5. #5 Re: Power window question
    Florida
    Ok, I'll take a look at it this morning. I'll do a follow up as soon as I'm done with it.
    gpbastard
  6. #6 Re: Power window question
    Florida
    !Scotty, you were right. It was just the two wires switched around from the factory. I crossed the wires and soldered them back together. The wires were fused into the socket so they weren't removable. Putting in those regulators is fun. Not hard at all and it only cost $33.00. Thanks again!
    gpbastard
  7. #7 Re: Power window question
    You bought a chinese regulator.. hahahahaha
  8. #8 Re: Power window question
    Florida
    Yeah, it says "made in china"right on the box. haha.. I put one in my RF window 7-8 years ago and it still works good. What I do is take some silicone grease and grease up the rails and that helps them go up and down easier.
    gpbastard
  1. Replies: 0
    Last Post: 05-05-2013, 05:05 PM
  2. Power Window Question
    By Bologna in forum General Tech Discussion
    Last Post: 10-14-2011, 06:05 AM
  3. power window question
    By mngtp in forum General Tech Discussion
    Last Post: 08-08-2011, 08:09 AM
  4. Power window question
    By adurn in forum Audio, Security & Visual Electronics
    Last Post: 03-26-2011, 01:00 PM
  5. power window slash electrical question
    By SlowPurpleGTP in forum General Tech Discussion
    Last Post: 06-22-2008, 09:25 PM
